U-joints
CORONA, CA
I just bought a 68 fj 40. It has a sound coming from underneath when I'm in 2nd or in 3rd when I deaccelerate. Sounds like shaft is dragging. Does this soundlike I need new u-joints? Be gentle, this is my first cruiser.
Climb underneath the truck and start wiggling things. If the DS wiggles look and see where it wiggles. If nothing wiggles, then you are typically good to go on the DS's and the bearings..
For best results, block the tires, release the parking brake, and put the tranny in neutral.
Since you're dealing with a 68, there's a fairly good chance that it's driveshaft bolts.
Hth
Mark A.
CruisinGA said:
check to be sure driveshaft u-joints are in phase...
2nd that. Line up the three grease fittings. It's pretty obvious, once you look at it. Mine was unaligned long enough to trash the pinion shaft bearings too. The u-joints are fine though.
