Recently had my ARB Lockers installed in my 1996 FZJ80, and have had only one hitch. It appears that the local shop did not install/tighten the U-Joint nuts/bolts/washers properly to the differentials.
I noticed this after about 500 miles when the front end had a clunk (unrelated, as that was the Panhard being a little loose). After crawling under the truck, I noticed one of the front four bolts to the diff was completely missing it's nut! Temporarily have put on a grade 8 nut from Kragen while waiting for the Toyota OEM one to arrive.
The main quesion is that the lockwashers (split style) were installed on the bolt-head side, not the nut. Based on my experience with other vehicles (and a MIL-SPEC background) the washer should be on the nut-side...
...so are Toyota LC's bucking the trend, or have all the fasteners been incorrectly installed?
fix, other than when the torque-wrench decided to come off one of the fronts and clonk me in the cheek...nothing a little ice and Ibuprofen won't cure.
