Spent the past 2+ weeks replacing the head gasket on my 97 80 and buttoned everything up last night. The last thing I'm needing to do is fill it with coolant. Silly as it may sound after all of that effort I am second guessing how I installed the TVV sensor on the head. So before I fill with coolant i wanted some guidance.
In the steps to install the head (page EM-51/52) it notes that you must use LockTite 242 and install so that the vacuum ports are facing the front of the head and it does not provide any torque value for the sensor.
This morning I was reading through the manual and stumbled upon the TVV section (Page EC-8) and it states that the torque value should be 22 ft-lbs for the sensor.
When i installed the TVV i used LockTite 242 and made sure the vacuum ports faced toward the front of the head. What my concern is, is that i know that the nut is no where near 22 ft lb tight. How have others accomplished this installation? What I don't want is for it to leak.
Best,
Zane
Best,
Zane
