Turn signal question!!!
Bountiful, Utah
Ok, I just finished my rear bumper on my 77 and I have a problem.
I am using LED lights for my Tail and Brake lights, those work perfect.
I am using a STANDARD 2 inch light for a turn signal light, it will not blink.
When I turn on the signal, both the front and rear signal lights light up, but they do not blink, when I turn on the Emergency blinkers though, they work perfect.
I believe the rear 2 inch lights are not drawing enough current to engage the blinker.
What could I do to remedy this situation?
Thank you
Daniel Tubbs
I had the same problem in my 74, only I didn't have LEDs.
Solution: throw stock blinker out and install a standard two prong blinker. I had to cut the socket off for the stock blinker and put female blade connectors on .Or you could make two jumpers with a male blade on one end and a female on the other.I don't think it matters which way you hook it up. Then just strap the blinker to something with a zip tie or make a fancy holder out of a hose clamp or something so it doesn't flop around (this kills them pretty fast ;) I'll get a part # of blinker for you if you want, but I think they're very common and are on most 70s and 80s domestic trucks.
landcruiserrich said:
I had the same problem in my 74, only I didn't have LEDs. Solution: throw stock blinker out and install a standard two prong blinker. I had to cut the socket off for the stock blinker and put female blade connectors on. I don't think it matters which way you hook it up. I'll get a part # of blinker for you if you want, but I think they're very common and are on most 70s and 80s domestic trucks.
I did ditch the stock blinkers. These are 2 inch trailer lights.
I think they may not draw enough power.
Don't you have to run a different style flasher for LED lights? (electronic?)
jaybonecrow said:
The ground, man. The ground. It plays havoc with the lights
Now the lights are working. Should I try a differant ground to see if they will blink?
I mean, when I turn the blinker on, they light up, I have no blinking action, could it be the ground?
I think that he's talking about the flasher. Have you changed the flasher? If the lights all light but won't blink it's usually the flasher. If these are LED you may need a different flasher than was stock - I've heard that several times but haven't installed any LED replacement bulbs yet.
Once again, these are NOT leds. these are standard bulbs.
Where do they hide the blinker on these 40's?
If they light up but don't flash, they still aren't drawing enough current to trip the OEM bimetal flasher. The quick and easy solution is to run the OEM bulbs, but wiring in an electronic flasher is a close second.
Could I install a Diode to trick the flasher?
Pin_Head said:
No, not a diode. You could put a resistor in parallel with the bulb filament to increase the current flow. I would suggest about 20 ohm, 10 watt. Another light bulb would be cheaper.
Ok, I am electrical stupid.
could I put a resistor in the positive wire or would I have to put it directly on the bulb.
I just built a new bumper, the lights are in, I cannot easily change the lights.
If you put the resistor in series or in line, it will cut the power draw. You need to put it in parallel with the bulb filament, eg. one end of the resistor to the hot wire; the other end to ground. Getting that electronic, solid state flasher is looking like a better option.
No s***, I can weld and fab all day, this wire crap is something I should look into learning.
I can pick the electric flasher at any parts store correct?
What is involved with installing that?
Sorry to be such a pain in the ass.
BTW, I follow you on the resistor, that may be a better option for me.
I would say it's the flasher/blinker, whatever you want to call it. You have installed 2" round incandesant lights not LEDs for turn signals right? I'll get you a part # for the flasher.
There were a couple of threads on this last month, so a search might turn up more specific info. I would just walk into my local parts house and ask for a 2 prong electronic flasher. You could also use a 3 prong, but you only use the center pin and one other one.
You can use another bulb as a resistor, it would be cheaper. Why not try this first with a couple of alligator clips temporarily wiring it in to see if it solves the problem. You could also see if you can get a higher watt bulb for the socket you have. Higer watts = more amps=brighter bulb=better idea.
I would get a more powerful blb but these are the 2 inch sealed plastic jobbies.
I will try the alligator clip bulb idea (boy do I sound retarded).
