Turn key and nothing
So I just got back from breakfast. Drove down to the diner a after eating I got in the truck turned the key and nothing happened. Looked down thought I left it in gear but nope it was in park. So I tried a couple more times. Nothing, not even a click. The only think I noticed is the dash lights would dim a little. Started thinking the battery was shot then I shock the shifter in park, and it started. Is there something under the shifter that need to be cleaned or replaced? Can't have that happen to the wife if she takes it somewhere. She'll drive it right to the Ford dealer and trade it in.
Make sure battery cables are clean and making contact, then make sure the Neutral Safety Switch (NSS) is properly aligned. If it is off a little it can mess up a lot of stuff. You say when you hit the shifter it started, that makes me think NSS. Mine was off about 1-2 mm and it caused me to lose my reverse lights.
Battery cables and NSS both easy fixes. Other than that, not sure.
Do you mean you pushed the shifter forward (and probably heard a click), and then it started? You may simply need to adjust your shifter linkage.
I know earlier this week when I left for work the reverse lights worked. How to I check the NSS?
As per the '97 FSM.
