- Joined
- Sep 19, 2012
- Threads
- 55
- Messages
- 604
Damn impressive build here
Forgive me if I have missed this, have you guys done anything to transmission?![]()
Already have a trans kit going in. Baktash and the guys at JMS have talked me into running it at 12lbs of boost so around 570ft/lbs for a while just because we aren't sure how things will hold up. I would expect I will be doing a larger trans cooler sooner rather than later.
That's one sweet build. Impressive numbers on a mainly stock long block.
You're on the right track with modding the tranny next. As long as you roll on the power, the drivetrain should be fine with that mod.
On a side note, have you considered adding methanol/water injection for insurance while hitting the "high" boost?
Yes if you don't have a way too cool the air like an intercooler you would benefit from water/meth injection but it is a very touchy thing in most performance car builders minds because if you loose a water/meth injection system you usually lose the motor when pushing it hard.
There are systems that have fail safe's built into them, but if you have a leak, run out of water, clog a nozzle, water pump dies, etc it could be a bad day.
BUT if you are not going to tune the system up past what the stock system can handle, and then are just adding it for a little more safety that is fine, but it would have to be used as a safegaurd not as a way to add more power. --- IN MY HUMBLE OPINION---
