Tub Height
Mine is 49" ,with 4" Downey lift springs and slightly longer shackles. I'm running 31" tires, but if I had 35's, it would only sit 2" higher. So figure about 51" if you have a 4+" lift.
1.5" front, 2.5" rear longer than stock shackles. So with the difference in our tire size, It sounds like you have 4" lift springs if your shackles are stock length.
This makes me wonder if I could actually fit 35's under mine? :)
Sounds like yours is a bit taller than mine...and mine has good clearance....
the reason why I have been trying to figure out the height...is because the PO put what I believe are chevy springs on it...and I have the MAF shackle reversal, so its very mixed and matched...
