Does anyone know if you can get a true trac for the front hi pin reverse rotation diff. I haven't been able to find any info. Thanks.
They used to make torsens for cruiser diffs, because i have one.
I like it in the front of mine, although i still break birfs.
Well Im running it in a 95 PU with PT 4wd. I just happen to have a hi pin cruiser third in the front. I'll probably put longs in at the same time. Thanks for the replies.
I'm gonna try and say this right, here goes....
Are the driving characteristics different in a hash way with a locker in the rear and a soft traction aiding devise in the front? (of an AWD)
My rational is this (NON VC coupler) the cruiser is basically 3 open diffs in my eyes making the torque flow or the way the diffs "feel" when to, or not work...?
If a locker only unlocks when torque is lost on the shaft and backlash unlocks it or the over/ under run of two axles traveling at different rotations...wouldn't that be hard in a AWD case? Would a locker and LSD setup upset the otherwise smooth balance of the diffs dividing power equally to each wheel?....and front to back?
A locker that does not UNLOCK is a full spool.
A full spool would create under steer and that might be a good thing in a heavy AWD LC
(keeping the front planted in high speed (highway) turn ins.)
I would not reccomend an lsd in the front of a full time 4wd vehicle. Tru tracs dont hook up well, so many people do run them in full time 4wd vehicles (popular in rovers), but you would be better of with one locker in the rear, than trutrac front and rear (althought tru trac is not available for the rear anyway)
I disagree, I ran two limited slips in my XJ and had easily the performance of the rear locker only crowd, but I also had a very flexy suspension and reasonable low gearing.
In any case, rear locker only is about 30% of the battle. Two limited slips are a waste of time and money. If you need 2 limited slips, you need a locker. If you need a locker, you need two lockers.
Long run, you can stay open or go dual locked. Everything else will make the trails you could already run open a little bit easier.
I also have had an xj (years ago) w/ trutracs but later ended up going arb. Keep in mind I have been in the differential business for a good portion of my life, and everything I own gets lockers or LSDs of some sort. Trutracs only give a slight edge over an open diff. I believe with front and rear and flexy suspension they work ok, because they need wheels on the ground to do anything. LSD's do certainly serve their purpose, but to work well offroad it really needs to be a pre-loaded style unit like the clutch style Japanese units work much better than the trutracs do. At least if you do one locker in the rear, you will gain a huge improvement and can later add one to the front.
