True lift height
South Carolina
I am ready to lift. After all i have had the cruiser for 3 weeks now. I have lifted several other vehicles before but i am newer to cruisers. I am hoping those of you with a lift can help me out. I am not likely going ARB bumpers but will build my own winch bumper down the road. Will prob keep factory rear. Just going fo a light expedition style rig for weekend hunting and camping trips. I am reading that even ome stock height springs lift the cruisers an inch over oem. Also hearing a 2" ome lift can be as much as 4 inches. So the only way i see to really understand what i want is to get some real data. I have 2 issues right now.
1) i am reading that the factory springs are soft and tend to sag so i want to be sure my rig hasnt already been upgraded.
2) I am looking to compile a list of actual lift Height with what others have to determine how much i want.
Can you add to the list the distance from center of the wheel to the top of the wheel opening, the "lift kit" you have, and if you have stock bumpers or heavy duty arb type stuff
Thanks for your help
Whl cntr to top whl opning---------------Lift kit --------------------------------------------------------Bumpers
Front 19.5" rear 20"-------------------------Stock?----------------------------------------------------------Stock - me
Front 24.5" rear 26"---------------------Js+2"spacers F&R-------------------------------------------------Stock - Thanks Muddinmetal
Front 23" Rear 23"-----------------------Iron Man 2" high rate --------------------------------------------Winch+Bumper, Sliders, heavy rear wt - Corbet is this correct?
Front 24" rear 24" -----------------------2" Metal Tech spacers (not springs)----------------------------winch+bumper, sliders, medium rear wt- Retro5 is this correct?
Front 22.5" Rear 23"---------------------TJM 50mm progressive +20mm spacer front -----------------winch+bumper, medium rear wt - Thanks HK33
Whl cntr to top whl opning---------------Lift kit --------------Bumpers
Front 24.5" rear 26"-------------------Js+2"spacers F&R-----------Stock
With flares
I measured mine stock, not sure how worn my factory springs were, but LXs tend to sag more, I added 6.6 in the rear and 5.3 in the front
I did an OME heavy, 850/863 lift. It is rated as a 2.5 inch lift. Net lift was 4 inches. I measured ground to center of flare on each wheel before and after. Had to use a 1 inch spacer on the front to lessen the "stink Bug".
Haven't measured mine in a awhile (and now deflared), but pretty much around 24" around, with flares.
Keep in mind what armor has been added and what has been subtracted as well (total) weight.
Front Bumper = MetalTech + m8000 winch
2" Metal Tech Coil Spacers Front
CreeperSleepers Skid Plate
MetalTech Sliders
Rear Bumper = 4x4 Labs w/o swingouts.
No 3rd seats.
Measured without spare tire onboard.
There are different spring rates available from most companies for the same published lift height. So in order to net the estimated height you need to match the right springs the the weight of your truck. If the measurements you listed were wheel center to the bottom of your flare I'd recommend a medium spring rate for your truck based on it now and what you have listed as future plans for it.
Without getting the exacts all four corners of mine were under 19" before my lift. I went with an Iron Man 2" lift but upgraded to higher than stock spring rates. Now all four corners are around 23" from memory. You could call it a 4" lift if you did not consider the truck sits almost at its OEM gross vehicle weight before adding gear/passengers. That was crushing my OEM springs. Now it rides like it did stock, just taller.
Edit: Flares on for all my measurements, TOY024C,TOY013B springs
Thanks, good point. Yes Flares are on... it will make a diff, I can measure the difference it makes tonight when I get home and post that. Please include flares or no flares in your measurement.
Tire size makes no diff with this measurement.
Measure center of the wheel to the top of the wheel opening.
Thanks all for your feedback.. Santa will know what to get me after I get enough info
Thanks!
I don't need a lesson in lift kits, just collecting the 3 items will do. By identifying the kit or springs I can determine what I want.. I will compile the data and go from there..
Not trying to be a jerk, but just looking for simple answers. Don't want to write a book for a simple thread post.
Can you measure from Wheel Center to opening and post that?
Thanks!
OME Heavy 850/863
Mine is 1995 80 series
Lift is 850/863
Front center hub to bottom flair 22"
Rear center of hub to bottom of flair 23 3/4"
Factors
Front has ARB bull bar, 12k winch with wire rope, and dual batteries
Rear has 3rd row removed and no other weight (ie no drawers and fridge is not in back) spare tire (285/75/16) in oem location and stock rear bumper.
Edit: lift is about 8 months old and has been heavily loaded and beat on, so all settling has occurred.
Ironman 6" lift
I have a 97 FZJ80 with the Ironman 6" lift kit.
Center of wheel to fender flare
Rear - 28"
Front - 27"
ARB front and rear bumpers. Tire hanging on the rear and a winch on the front. Nothing else too heavy in the truck right now.
I think it would be easier if you would post how much lift you are looking to gain. Then we can recommend a lift that will achieve that with the mods you listed.
While that may be true, the original request in this thread was
"Can you add to the list the distance from center of the wheel to the top of the wheel opening, the "lift kit" you have, and if you have stock bumpers or heavy duty arb type stuff"
I'm aware of that. Believe it or not, I learned to read a while back. However, if the OP only wants to run a lift that puts him 2" over stock, then it seems frivolous to list the measurements for taller lifts. If the OP is undecided, then I retract me previous statement.
I think this thread is a great idea. I too am interested in this data, as I am looking to lift my rig as well. I also propose that we add a broad-side image of the rig (before and after lift if possible). I will go out to my lx and take some measurements for a stock vehicle, as I too believe that I have suffered from some serious sag.
Michael
