I have same issue. I also ordered vaf connector which I plan to replace. While the motor was running I measured the voltage signal inside vaf meter and external plug. Connection was not solid and reading were lower at external pin. By removing the 2 screws and bending the pins downward helps with improved connection. I even messed around with spring tension to change the rich and lean settings.
3rd pin from left is blank and not used.
