Trouble pulling front third member
Chicago, IL
Maybe another dumb question, but is there a trick to pulling the front third member out of a 72 FJ40? Axles are out, 10 nuts holding diff to axle housing are removed. Looks like there are a few built-in lips for beating the diff off, but it's not budging so far. Bigger hammer, or am I screwing something up?
Stuck-on gasket. Common. Put your bottle jack under it forward of the input flange and put a little upward pressure on it and then wait. It'll pop, given a little time.
Appreciate it all. Should have mentioned axle is off the vehicle. Little targeted force with a flathead separated stubborn gasket. Thanks!
Use a small bottle jack under the tip of the third (near the pinion flange ) it will pop out
When ever I use this method I leave some of the nuts on loose so when it pops I don't have to worry about it falling to the ground. Doesn't apply when the axle is out but in the future search could come in handy.
