Trollhole carb questions
Uvalde Tx.
Got my carb instlled and it performed as expected.
Any ideas on lengthening the center bolt that holds the filter housing onto the carb throat?
Has anyone experienced the secondary hanging very slightly causing a rich condition at idle?
I lightly touched the linkage and it closed.
Found the throttle bracket was very close and the cotter pin may have interfered so i tweeked it slightly so there is good clearance.
With the throttle wide open the secondary is very smooth with full travel. Thanks
Also i put a small spacer under the bolt for air cleaner and it should be fine.
