Troll
Seneca, SC
Need help installing a weber carb. Bought it from Alan yesterday. No instructiions. I installed one 5 years ago but had instructions. Need to know how to connect the fuel line and the return line. Picture would be great. Thanks Coach
No return line. Just cap it. As far as feed line I'd cut the fuel line at the carb and add a short section of rubber fuel line.
Here is how mine was done. Also the pcv line should go to the base of the carb and the connection under the air cleaner should be connected to the valve cover vent.
First pic. You see where the fuel line and the pcv hose cross just before the carb? Right below that intersection on the pic is a small plug that is on the adapter. That is where the pcv hose should be. Or it can go to a vacuum source somewhere near the base of the carb. Did you get the adapter base with the carb?
Thanks
for your help Marshall. See if you can find that nipple and I'll buy it if I can't find one. Thanks again Rick
