Trick for removing gauge cluster
West Cochise Stronghold, Arizona
Website
www.exploringoverland.com
I've seen several threads here centered around the fiendish difficulty of removing the FJ40's gauge cluster. The biggest problem is the lack of access to the speedometer cable in order (on my '73 and similar years) to both squeeze the plastic retaining lever and pull the cable out. I just went to replace my dash bulbs with LED units, and in doing so found that my speedo cable was even more stuck than usual. I simply had no success with my arm stuck up near the parking brake trying to both squeeze and pull. My solution was to undo the two front screws, tip the cluster outward, and run a zip tie around the clip to squeeze and secure it. With the cluster tipped back in all I had to do was pull rather than pull and squeeze, and the cable popped right out. I hope this might help someone else. Installation was just the reverse of removal—stick the cable back in, tip the cluster out and cut the zip tie.
Great tip. Make sure to disconnect the battery, there are a lot of current and sensitive gauges there.
Especially when the ammeter connections find a piece of the dash.
