trashed spindle. chinese birfield
my wheel started smoken last week 5 miles from home. I thought the caliper on the pass side had frozen up. I just drove it home. Bad idea
I couldn't get the spindle nuts off. cut them with a die grinder. the outer bearing was a pile of pieces and the hub had tilted consequently. the outer shaft of the birfield contacted the inside of the hub and ground about a 16th off the outer shaft where the hub and shaft made contact.
Lot more money than I had hoped. I went cheap and didn't buy OE but got the MAF gasket/seal kit with bearings. also got the MAF brembo rotors and some pep boys rebuilt calipers
got a used hub and spindle ($70/$75)
baught an ebay $150 chinese birfield too. this aught to hold up great:frown:
I can sell you an OEM from my spares for $50 if you need it. No idea if it is a clicker or not...you would need to move the ABS exciter ring from another.
Don't use the MAF axle seals, GO OEM for those. It isn't worth tearing it apart over and over again. I've been there and done that. And I'm really stupid because I did it twice both with the same end result, having to do it over.
thanks for the birf offer Dan. but now I have 3 oe spare birfs laying around (1 I cant put back together so I dont take them apart anymore) I want to try and break this chinese job. I am heading up to shaver for memorial day weekend and will give it a go
The MAF seals didn't look the quality of the oe parts I used for the last repack. the gaskets looked cheap too. too late-they are installed. I dont think they will be there long anyway as I got 3-link on the brain
37" swampers get mounted today
I learned it all right
I wonder what caused this carnage. the trunion bearings were tight. the birf was packed with grease although it has been almost 50k miles since last repack. I changed the brakes a 1000 miles ago. I wonder if the spinle nut loosened. I supose that realy hot breaks could destoy the bearing and cause the failure but Im not sure
