Transmission temperature on a late model 100 series
As a confirmation I talked with SG tech support. The parameters I posted above are in fact what they loaded in your 06 LX and good for at least 04/05/06 Toyo/Lex models. FWIW They do not believe you can pull data from both sensors. Checking my TFT operating temps they suggested I compare TFT against water temp, intake air temp first thing in the morning- water temp and TFT were with in 1 degree of each other at start up today, so I guess my TFT temps are pretty accurate. I'm surprised my trans runs so cool, suppose that's not a bad thing I guess.
These are the X-Guage parameters to retrieve TFT data for ISO protocol.
Scangauge:
TXD: 686AF121B4
RXF: 046105B40000
RXD: 2808
MTH: 00090005FFD8
Two year thread revival... These codes are not showing anything for my 06 LX - wonder if I need some special sauce?
This worked for transmission temps on my 2007.
Gauge: Transmission Temp (F*)
TXD: 07E021D9
RXF: 032100000000
RXD: 1808
MTH: 00090005FFD8
Notes: CANSF pre 2010
Hopefully this helps someone as I could not find this code for the 06-07 models anywhere on the forums.
