Transmission service
Auburn
Changing all the fluids to synthetic on the 80 that I recently bought ('97 with 113k) is high on my priority list so naturally the transmission is on the list. The FAQ does an excellent job of covering this subject, as does many other threads that I've read during my extensive search of this subject.
I liked the exchange method described in the FAQ which entails disconnecting the cooler line to catch the fluid into a bucket, etc. and may go this route. However, I was wondering if anyone had ever used a shop which uses a "pump inlet flush machine" as described in this link?
Transmission Flushing
Basically, it sounds like they drop the pan, change the filter, and then flush new fluid into the transmission via the pump inlet and catch the old fluid as it returns to the pan inlet (with the pan dropped). The pan, with new filter, is then reinstalled and the fluid level topped off.
I would welcome any comments from anyone that has experience with this type of flushing. I haven't looked for a shop yet so I don't have any experience with how difficult it might be to find this service. I saw in several threads that Slee and American Toyota both use transmission flush machines but nowhere was which type explained.
I don't want to start a new thread on synthetics as there are many many already here and the topic appears to be well covered. I have decided that between Mobil 1 Synthetic ATF, Redline D4 ATF (haven't seen any recommendation on Redline D6 ATF but it looks like it would work as well), and Amsoil Universal ATF that one couldn't go wrong. Again, not to start a new thread on transmission synthetic fluids but if anyone has had a bad experience with any of these products then it would be good to know.
Thanks! See now that's the problem...I only went through 4 years of threads! .....and I thought us Auburn types were the thorough ones; little did I know. (I actually read the first thread before but not the second one and it's much more informative.)
Still curious btw if anyone has used this kind of machine. I suspect that American Toyota does as Dan said (in the second thread) that their machine is made by BG and I remember from somewhere during my exhaustive research (over the last 4 years) that BG made the type of machines that hook up with the pan dropped. However, the description of the technique used doesn't exactly jive but it's close.
Again, sincerely thanks (ignore rhetoric above).
If you want to know for sure, call or PM Cruiserdan. Or call up Slee Off Road. They're all good folks, even if Dan can be a little too serious.
That's a good suggestion. Normally by the time I think about phoning someone back in the US it's bedtime here. I will be flying into Birmingham in early March and will be in the area for a week. That will be a better time to phone, after I've driven this beast for a few days.
You know how it is though when these midnight ideas come around......transmission flush....now how would I absolutely, positively go about getting that done. :p
Again, thanks! I owe you a cold beer. :beer:
No problem. Just PM Christo Slee or Cruiserdan and they can probably tell you what you need to know. Where is the truck right now? If you need someone in Birmingham to drive it around town, or get drunk and drive it eighty miles an hour off road (private property, of course) in the country, let me know.
No problem. If you need someone in Birmingham to drive it around town, or get drunk and drive it eighty miles an hour off road (private property, of course) in the country, let me know.
They only go 80? Why did I buy one of these???
Finally found someone with a B&G machine that knew their business. While my Landcruiser was visiting my sister in Atlanta I had the front axles done at Urban Landcruisers and all the diff fluids changed to Redline synthetic.
I then noticed in someone else's thread a recommendation by barCruiser in Atlanta for transmission service by these guys:
ToyoTechs - Atlanta Toyota and Lexus Auto Repair, Service and Maintenance
I spoke to them over the phone and they had me convinced so I ordered 4 gallons of Amsoil synthetic ATF. Although the tranmission holds 12 quarts, they said they needed 16 to do a complete exchange with their B&G machine. Normally they said they wouldn't drop the pan on a landcruiser with 113k but I got them to do it anyway.
They drained and then dropped the pan, inspected the screen/filter, checked the magnets, reinstalled the pan, toped up with their fluid (3 or 4 quarts) and then ran the Amsoil in. Just got off the phone with them and they said the pan was very clean with little or nothing on the magnets or in the filter.
I asked my brother in law how it shifted and he said "just like it did when I drove it in." :) (Which is fine because it shifted very smoothly before.)
Anyway, just wanted to give the owner Fred and all his guys a recommendation for anyone in the Atlanta area.
I'm down to the power steering flush as far as baseline PM's and I'll do that myself this summer. Bought 4 extra quarts of Amsoil ATF to use on the 80 and the 4Runner power steering (hopefully 2 quarts each is enough).
RavenTai's method is great, even for a 0.05:banana: like me, no need to put it off. Take it slow, turn from one side to the other, then refill. Otherwise air gets sucked in. I put 4qts D4 ATF through it for good measure. CDOC on eBay, located in VA, can get you Redline stuff fast. I'm in NC and I usually get it next day from an AM order.
