Transmission Oil Leak component??
New Zealand
Hi All, I have just purchased a 2000 100 series cruiser which has a small oil leak which I think is transmission fluid coming out a loose bolt / sensor or something. If someone could let me know its name an how to stop the leak that would be great, youtube hasn't helped!! I don't want to try tightening it without knowing what I am doing. Its the shiny bent pipe just above the rag above and just to the right of the 2 vertical lines on the drive shaft. Oil only leaks when the engine is running. Cheers!
Try using a "flash" on your camera. I can't see anything!
Hmm... Yeah what are we looking at? Also a wider angle picture and then a mid and finally a close up with @2001LC mentioned with light.
Most smaller issue on here can be solved if we know what we are looking at.
