Transmission issues?
My 97 LX450 has squealed a few times when going in reverse up a hill when I give it some gas, but when I give it gas easily, it doesn't to it. Also if I lock the center diff it will not do it at all. Even if I give it gas. What can it be? Is it the Transmission going out, or is it something with the transfer case. She has 254k miles on it.
I'd guess striped drive flange?
I spoke with the guys at Slee offroad and they told me for some reason the 96 and 97 FZJ80 and LX450 will squeal in reverse and they don't really know why. It doesn't mean that the transmission is bad because they will do it from day one. This gives me relief but I will still keep an eye on it. He also said that it is not wise to have a transmission shop rebuild it because they are never the same, the best thing to do is go straight to the dealership and buy a remanufactured transmission.
Have a couple known to be good transmissions in reserve because the dealership is steep.
Been discussed; there have been TSB's concerning the noise in reverse or when shifting in or out of reverse, has to do with a couple of balls and/or spring changes in the throttle body. Apparently there were running improvements and by mid-97 those improvements were completed, IIRC.
What is the date of manufacture of your 97 LX450 (check the data plate/sticker, left front door).
If possible allow some hesitation between shifting into R and gassing the engine.
I have the same issue with my 80 in reverse. When I gas it, it squeals. Happened yesterday in some deep sand. I dropped the TC in low and gently backed out. Makes me paranoid because I don't want to loose the tranny. Manufacture date: 10-'96. Vehicle has 180K miles and very well maintained.
