transfer case replacement
t case
Im with Doug
keep the old tcase
But that said, did the new tcase fix the problem/noise?
The transfer case replacement did fix 99% of the drivetrain problems. Right before I took it in you could actually hear loud metal on metal grinding.
I actually have the old transfer case sitting in the garage...
Break it apart for pics!!!!
TPS
The other 1% was still the jerking that would occur while on the throttle. I replaced the throttle positioning sensor (TPS) and fixed that.
Essentially the engine would die as I was driving and when I would hit the throttle it would kick start and the drivetrain would slam into each other.
hope this helps others with ....
When the VC goes out does anything else in the TC get damaged?
Goes out as in seizes?
No, not usually. Just more wear on the driveline, tires, etc. till you get it pulled.
Curtis
What he said.
If you have a siezed VC, then lock the CDL and pull the front driveshaft. Drive it that way until you have time to pull the VC. Eliminates the extra wear on the drivetrain, but you no longer have AWD.
I bought a 96 a few months ago and between 65-75 the truck would vibrate. I had the driveshaft balanced and it got worst. I took the driveshaft off and the truck drove fine. I didn't have to lock the CDL to drive without the DS. I had the front end rebuilt, all bearings were shot and the gears were destroyed (everything was broken). Now it drives like a champ but I still have not installed the front DS because I don't want to destroy the rebuild that was just preformed. I want to tear into the TC and replace the VC. I bought a used TC and think it would be easier to just replace the VC than replace the whole TC. I now remember that when I bought the vehicle 3 tires were the same size but one of the front tires was smaller. I guess this caused the damage to the VC.
Yep, miles and miles of straining and heat build up as the two shafts spun at different speeds. Toss in low fluid or a hot climate like AZ and the unit will toast.
DougM
replacing the entire tcase is cake. i replaced mine last spring
all you need to do is pull out the easily accessable tcase shifter linkage pins, remove the speedometer cable and a few electrical connectors, remove rear drive shaft at the tcase, and then remove the easily accessable bolts that hold the tcase to the tranny
it helps if you loosen the tcase crossmember bolts about 3/4" at the frame so you can easily position the tcase on crossmember.
be sure you have a buddy or two (a strong one helps) to help you bench press the tcase on and off. dont bother using a jack as you dont need it
you can easily do the swap before lunch on a saturday
On an AZ rig I wouldn't replace the VC, just pull it out. For our driving needs it's pretty much worthless and without that big drum in there, the transfer would hold more fluid.
Have you driven it with the CDL locked, is there a difference? With a good VC, you can drive without it locked, but there will be some slipping.
Can I drive it with the CDL locked and without the front DS? What should happen when the CDL is engaged? With the VC out, do I need the CDL button and 7 pin mod?
Thanks!!
DougM
Is it true that when a VC siezes,locks up or otherwise goes "bad" that it is the internal fluid that has gone bad? If that fluid could be replaced, would it then be fixed or "good to go"? Or does the heat damage the internal metal parts, also?
I engaged 4 lo and the diff lock and abs light came on. 80 drove fine without the front drive shaft. So is the CDL button needed and pin 7 mod or can I just remove the VC and be ok?
Thanks!!
The full time transfer has a diff to allow for better street behavior. Without a VC, if a driveshaft were removed the rig wouldn't move, all of the drive rotation would go to the disconnected flange.
The VC is a fluid coupling that acts like a variable limited slip diff. It attempts to keep both shafts turning at close to the same speed. If working correctly and driven with only one shaft, there should be some slip, like a slipping clutch or torque converter.
The CDL locks the diff, so front and rear output/driveshafts have to turn at the same speed. If it's locked and a driveshaft is out it should be direct drive, no slip. The CDL button and 7 pin mod give you full control over when it's locked. For your purpose, shift low to lock the CDL, remove the "diff" fuse, shift high and drive, it will stay locked until the fuse is reinstalled. When a driveshaft is removed this is the "proper" configuration to drive in.
I have one that is bad, locked up, but haven't cut it open, yet. They have silicone fluid, my experience is; when it goes bad it loses it's ability to grip, would slip more. My guess is; locked up failures are from a bearing failure.
Sorry Kevin, but I'm still a little confused. My LC is not locked but still drives without the front drive shaft. I never locked it, pulled the fuse, and put it back in HI to drive. I just removed the drive shaft. If the VC is removed, the LC would not move unless I lock it first right? I guess my question is how am I moving with the front drive shaft out and not locked with the VC still there?
The VC will allow for some movement, then it will seize, allowing full movement.
The only problem is that once the VC is seized up, the transfer case will act as though it is in true 4WD and not allow any slippage between the front and rear driveshafts, which will cause binding and possibly ruin things.
Running without the front driveshaft while the VC is seized is just like running in regular 2WD. No more harm than what was already done to the VC.
Thank you. I guess it's time for the CDL switch and VC removal.
A cheap CDL switch can be had at a local junkyard. A hazard switch from a Tercel seems to be the most common el-cheapo option.
There's a yard by me that has a 94. I'll check it out. The pin 7 mod is only to unlock the diff when in LO correct?
