transfer case replacement
HI to CA
Took my FZJ80 to diagnose clunking/jerking/whining sounds from the drivetrain at the stealership. they told me I need to REPLACE my transfer case at $4000.
The drivetrain is not in bad shape and the clunk/jerk doesn't happen that frequently so I assume its not totally shot.
Any suggestions/options out there? Should I try and replace fluids myself? Can I get a rebuilt one?
Any ideas would be greatly appreciated. Thanks
Welcome :flipoff2: as we say at MUD !!!
What year is your 80, just to clarify? I saw you said FZJ and that usually means '93 - '97. If that's the case maybe it's just your VC (Viscous Coupler) in your transfer case (Center Diff as we refer to it). There's threads here to remove it and then it'll perform like the '91-'92 transfer cases. Prolly the cheapest way to go if that's your problem.
Based on what you've provided, and not knowing anything about your vehicle (year, miles, history, etc) there is little to go on. This place is rich with information but you've got to provide guidance.
DougM
... they told me I need to REPLACE my transfer case at $4000.
We rarely see bad transfer cases in the 80-Series. As 80t0ylc mentioned, we get the occasional failed VC due to some PO running different sized tyres or some other type of abuse.
Whenever you post a question here in 80 Tech you need to give us the demographics of your vehicle, US model? maintenance history? year? mileage? prior mods? (e.g. the guy in the other 'bad transfer case' thread failed to tell us he had switched to selectable front hubs.... duh.)
When you describe the problem don't describe it like a girl. Give us tangible information that we can process.
:cheers:
(... apologies if you are in fact a girl. If that is the case my advice is don't describe the problem like a soccer mom. If you are a soccer mom then why the hell are you on IH8MUD?)
-B-
blaze
HEEEELLLLLLL yeah you guys are the shiznit...yup.. i love it here already.
the FZJ is a '94 w/ 165k miles US spec, NO lockers. all stock
owned by my dad for 7 years now i cashed him out for it. i wanted the dealer to look everything over and tell me exactly what it needs:
TRANSFER CASE REPLACEMENT: $4,043
FRONT/REAR brake pads/rotors, repack bearings: $1,038
HOOD STRUTS: $201
FRONT/REAR DIFF service: $245
:flipoff2:GRAND TOTAL: $5,792 big U.S. dollars! :flipoff2:
This is turing into a project at the wrong time but it will get done piece by piece and def not at that bill. however the $165 for the diagnosis was worth it!
TRANSFER CASE: I did look at the p/t kit, but i like the feel of f/t in an suv
SHOCKS: going w/ Rancho RS5000 b/c stocks are shot, keeping oem springs. best deal for what i wanted to spend.
BRAKES: wanting to upgrade to slotted and longer lasting pads, better brake feel.
DIFF: want to add lockers so will service all at the same time.
Ummmm........................what? (knocks on screen) anybody home??
DougM
OK, a piece at a time. Start with the transfer case - the rest can wait. You can help to troubleshoot this yourself by adding the CDL (Center Differential Lock) switch to the dash. A search on MUD with CDL as the keyword in the 80 series forums will give you the background you need. Basically, it allows you to manually lock the transfer case so you could remove a drive shaft and see:
1. If
"clunking/jerking/whining sounds" go away while you are driving it.
2. If there's a difference when you engage the CDL or not.
If your VC is seized up you won't need to engage the CDL to move your rig with a drive shaft removed.
MUD is here to help give tech advice - most of the items on your list are do-able by you with some help, maybe. There's always some one on here willing to chime in and give his .02 worth. That's part of the addiction. Keep us posted and add a sig line with your mods and info to help those who are trying to help you.
... clunking/jerking/whining sounds from the drivetrain
... and the clunk/jerk doesn't happen that frequently
So far, we know more about you and your relationship with your Dad than we know about the "transfer case" problem you are posting about...
"The drivetrain is not in bad shape." - What do you mean? Please elaborate.
" ... and the clunk/jerk doesn't happen that frequently" 1x hour, 2xday, every 7 miles? On your birthday? Please elaborate.
" ... clunking/jerking/whining sounds from the drivetrain" - From the engine? Underneath the truck? Front, back, middle? When you put it in park? When you stop on an incline? Only at Dillards? Engine running, tranny in park, transfer in low? Turning corners? Please elaborate.
-B-
drivetrain
-B-[/QUOTE]
The tranny is ruled out as it was recently serviced and looked at again by dealer.
ALL the symptoms w/ transfer in HI and every time I drive it daily:
cold engine: jerks into R and D
warmed up: clank sound from under the hood when drop in D (no sounds to R)
drivetrain jerking: feels like from the middle, jerks on deceleration or very lightly on throttle, downhill w/ cruise control on
whining like whistling sound: deceleration all the way to stop
on the throttle no problems, upshifts are smooth
i appreciate the help, and for tearing me a new onE:bounce:
Find a competent (non-toyota dealer) mechanic. One that specializes in Toyota trucks.
Sounds like in your matter Toyota would rather take the shotgun approach than take the time to analyze and find out exactly what's wrong with the transfer case. Heck removing, rebuilding and re-installing the transfer case properly (all new seals... etc...) can be done for around $1600 from a competent mechanic. Maybe less if none of the major parts are replaced.
Search for your answers before you post up, and post usable information if you want a usable competent reply.
Otherwise, you (may) suffer unnecessary bashing from some of the self-imposed resident gurus... I mean elitists.
Now we're getting somewhere.
Have you had the U-joints checked? This kinda sounds like it could be the problem. If you are comfortable with checking them yourself then you are looking for excessive slack/play in the joint. You can get a feel by doing both the front and the rear and seeing how much difference there is between the two. Do this with the truck on level ground, tranny in park, engine off. Grab the drive shaft with both hands and attempt to turn it.
(Sorry for being direct.... sometimes guys need to be re-focused if they are going to give us information that can be used to help them isolate a problem.)
-B-
Beo,
Your post cracked me up. Practically could FEEL the desire to trouble shoot, but frustration at lack of usable input...Heh. Been there and posted that. This one should be somewhere as an auto post Mud reaction to similar lack of info posts.
Carry on.
DougM
And I could hear your scream earlier this week all the way from Idaho to here in the foothills when that guy finally told you he had after-market selectable hubs. You were working and working with him trying to get him to check the drive flanges... and come to find out he didn't have them! You were right about the problem though. :D
:cheers:
-B-
Yeah, that was another classic. One of my favorite Mud activities is watching the thread grow when there's no real information. Lot of people with excellent speculation, but in the end the guy drops a bomb, like "wups, my Moms car is an FJ60 - sorry guys.."
DougM
UPDATE
After much time the 80 is back with a replaced transfer case.
Dealer determined it was the ADAPTER SEAL (seal between transfer/tranny) failed causing fluid to mix. So this $12 seal killed a $4000 transfer case and potentially the transmission.
Decided to go with cruiserparts.net used transfer case for $750
They shipped it directly to the dealer in about 7 days where the dealer swapped the transfer case. Labor was $847.
Here's a pic on a test run to lake edison fresno, ca
Nothing personal, but still not buying the transfer case was damaged. These are massively stout solid gear driven center differentials where the rest of the world has been using chain drive transfer cases for 25 years. I'm hoping all your symptoms went away, but guessing if they did it was from adjusting things after the install. What did you do with the old unit that was removed??
As for their seal diagnosis, transmission fluid in the center differential mixed with the gear oil wouldn't do a thing unless there's an incompatibility of a metal I'm not aware of. Transmission fluid is simply super highly refined oil and makes an excellent lubricant. Please post the Toyota dealership name so others will be aware of their diagnostic capabilities.
DougM
