There's a yard by me that has a 94. I'll check it out. The pin 7 mod is only to unlock the diff when in LO correct?
Bingo.
Sorry Kevin, but I'm still a little confused. My LC is not locked but still drives without the front drive shaft. I never locked it, pulled the fuse, and put it back in HI to drive.
I just removed the drive shaft. If the VC is removed, the LC would not move unless I lock it first right?
I guess my question is how am I moving with the front drive shaft out and not locked with the VC still there?
... The only problem is that once the VC is seized up, the transfer case will act as though it is in true 4WD and not allow any slippage between the front and rear driveshafts, which will cause binding and possibly ruin things. ...
), do some turns to see how much sliding the tires do. Lock and unlock the CDL to compare.... VC removal.
Toss the shaft back in and bring it to the CSC meet in Tempe next Friday (the 20th), that's where our favorite VC test skid pad is,,, Quick Trip.![]()
I'm a little concerned about putting the DS back in because of all the damage that was found. The gears in the front diff were ground to nothing. If I install the front DS and the VC is bad, won't it damage all the work that was recently done?
Does removing the VC effect the ABS?
What are the cross streets and time?
I'm a little confused (as usual, I might add). Enterconnect, in Post 33 above you state that you drove it around fine in LOW RANGE which Kevin may not have noted. In low range, the VC is bypassed and the center differential is locked automatically as indicated by the difflock light you mention. So in low range you can drive without a front shaft because the center is locked. In high range, the VC should cause serious driveability issues due to slippage and of course this will damage the VC.
So. Are you saying after you drove it in low range w/o the front shaft you were then able to put it in high range and drive normally? That's what's got me confused here - are you driving around in high range without the front shaft? That would be abnormal.
DougM
That is exactly what I'm saying. HI range, no drive shaft, not locked. That's where I'm confused too. I thought you had to be locked to drive in HI if your drive shaft is not in, but I'm able to drive without it being locked. Here are a few pics of the busted front gears that were replaced.
Um, Doug was specifically asking about low range, though your answer seems to indicate that the VC is siezed.
Scenario:
CDL Unlocked
High Range (or low range with 7 pin mod)
Good VC
One driveshaft pulled
Results:
The engine will wind up a bit as you apply throttle. You may feel like the transmission/t-case is slipping a bit until the VC fully engages, then the truck should drive as normal (at least until you stop again). You do not want to drive for very long in this case lest you cause the VC to overheat and sieze up.
Scenario:
CDL Unlocked
Bad VC
Results:
The truck will drive as normal. It will drive the exact same as if the CDL was locked.
Scenario:
CDL Locked
High Range or low range
Good VC or bad VC
Results:
If you cannot tell the difference in driving with the CDL locked and the CDL unlocked (especially when starting from a dead stop), it is likely your VC is siezed.
