Transfer Case Protection
Bentonville, AR
What do you folks think about the IPOR v/s Slee's setup? I know they are both great products and would buy one of each if I had another 80 in the garage. I am looking for some observations.
Thanks,
Josh
I'd like to observe here that you have no more room for another 80 in your garage - what would you do with the '40?
I'm contemplating the slee - looks good enough to park the truck on. Don't know much about the IPOR, I'll check into it.
Dan.
I believe the IPOR is stronger and gives you more clearance, because it replaces your cross member. But you have to pay for it! Slee's is alot less $$.
The new Slee is the Shizzle......
Thanks,
Josh
They were both too weak for me. :hillbilly:
(Link in sig).
What I would have gone with if I had the $$$ (and it was even available...which it still looks like it's not....).
Yes, it replaces the OEM tranfercase crossmember.
That one is a pre-production prototype on my wife's truck. You would need to contact Christo to see where he's at in the production process.
Thanks Dan. It looks like a great combo. I liked the x-member replacement design and it sure looks a lot stronger than anything I have seen offered. What is the thickness of the plate?
It's ~3/16 inch IIRC.
And monkeys and fishes and frogs and octopus, and rabbits.......
IT'S NOT MY TRUCK!:eek:
I have the IPOR skid. I have been hitting the snot out of it lately. REALLY glad it's there. Between it and the OLD slee skid, IPOR wins!! That new slee skid does look really nice. Maybe even a tad more belly protection then the IPOR plus a more uniform skid surface. I think the later is the real key IMHO.
I've been considering redoing my belly plate, and going with a more contoured shape to provide more clearance on the DS while still wrapping around the t-case.
But from looking at the bottom of my skid plate, I've had things go at weird angles (including nearly sideways). My concern is that not having the flat and uniform surface, you're just providing more stuff to get hung up on.
I'm definatly going to redo mine at some point and make some changes. Not 100% sure yet on what they will be, but keeping as flat and even as a surface as possible will definatly be one of them.
Hellow this is my Transfer and Automatic Transmission Protection, is made by Duraluminium 6mm. Very well done, i think!!!!!!!!!!!!!.
Miguel :beer::beer::beer::beer::beer:
exactly. Last time i was out, the IP skid did it's job for sure. But i had to get a tug off a rock after getting hung up on it from an odd angle. If i would have had a complete flat surface that would not have happened.
But, for what the skid protects, it does an excellent job of doing that.
Miguel, That is a beautiful skid!!
