transfer case help
mwalls54
Cruiser Nutjob
Roanoke, VA
is it possiable to replace the gasket on the front extension housing that bolts to the main case with out having to tear down the whole case? if not how hard is it to remove and put back together? i have untill noon tomorrow to get it together.
No need to tear down the case to replace that gasket alone. I think you need to be in 4WD in order to reassemble easily though. It's been a while since I did one of those transfer cases.
Drain the oil in the tcase, drop the driveshaft, remove the five bolts, clean your mating surfaces, install new gasket, bolts, driveshaft, and you are done.
No biggie.
Good luck!
-Steve
so do i have to mess with the shifter linkage? thanks guys
No that is an interference fit at that point.
ok that part was easy, but the problem i have it leaking is one of the lower bolt tabs on the driver side was broke. any one ever run across that? and i am going to jb weld the tab back on and instead of using paper gasket i am going to use lots of black rtv.
