Transfer Case Drain & Fill...
State of Flux...
Last weekend I did a drain and fill on the front and rear differentials and the TC. After completing the job I drove across town only to notice ALOT of gear oil leaking and blowing all over the under chassis all the way to the rear of the vehicle. I believe it was coming from the TC. Also, I believe I over-filled the TC as it was still pouring out of the fill hole when I re-inserted the fill plug...I know, stupid mistake. However, it seems the problem of leaking is now over. My question is this- will the transfer case 'puke' out the excess gear oil via an opening somewhere on the TC? Am I now good-to-go? I can't think of anything else it could be??? Any / all info. or advice is appreciated...Thanks
regular Mobil brand 80W-90 gear oil for me...just drain the TC completely and then refill to just below (i.e. approx. 1/8 inch) fill hole and you should be good.
There is a ball and spring vent in the t-case that I imagine could leak some fluid. I took mine into Toyota for a drain and fill and now mine leaks. I suspect they overfilled, and I know they used different gear oil. Going to drain mine and refill properly tomorrow and see what that fixes :)
I just drained and refilled the TC - it had 70K on the oil - it looked like new when I drained it - I filled it properly (no overfill) now I have a leak in the front extension housing seal :crybaby:
It leaked enough to have to refill it 8 oz or so in less than 500 miles - I am not ready to remove the complete TC to fix it yet...
