My FSM says the transfer case should take 1.8 quarts of 90wt, but it started coming out the fill hole after only 1.2 quarts. Is there a bunch of fluid that doesn't come out when you open the bottom drain hole? It's a 3-'78 4-speed.
I'm still trying to track down a vibration that started on the way back from Surf & Turf. With the transfer case 'full' it seems toned down, but it's still fairly prominent at around 55mph. The drive shaft is in alignment, if that's what you started thinking.
Anyone think my xfer case is just old and ready for a rebuild? It probably has about 90k miles depending on how much I believe the PO.
