Looking for some info on transfer cases, just learning how to use mine and had a couple questions that I'm not sure if should be concerns....for a '91 w/3fe. While driving down a somewhat steep hill and in Low trans gear and low in transfer case, center diff auto-locked, it cruised no problem, very little if any braking was needed and all was good. But when I was on flatter ground, like transitions between hills, the trans would pop out of gear. Also, if I shifted to a higher trans gear and went a little faster it would also drop out of gear.
Is this normal? Is there a proverbial 'speed limit' that I should be keeping an eye out for or do I maybe have some transfer case issues that need to be looked at?
