I’m not trying to rain on the parade here but you must be very careful using an infrared thermometer for such things.
For example in the photos posted it appears the temperature reading is taken from a distance, likely with the assumption that the laser is where the measurement is taken. This is not true. I’m not going to get into too much detail but the infrared reading fans out like a cone that gets wider as the distance increases. There is also an enormous effect of the materials surface, shape, and the angle of attack on the measurement.
Here’s a quick google reference:
Infrared thermometers are very fast (instantaneous), provide a good indication of temperature and allow you to collect temperature data at a distance.
blog.thermoworks.com
There are better articles, but you can do some experiments for yourselves to learn a bit more about how the infrared gun reacts.
The fluid temperature is what is the area concern in situations like this.
One thing to note is that the fluid settles down to the bottom of the transfer case when the vehicle is in motion. If the engine is idling In neutral when the measurement is taken the gear set will keep the fluid distributed in the case. This is likely one of the contributing factors on your measurements.
If you want the most accurate surface temperature measurement you would best be suited putting the transfer case in neutral and the transmission in gear to distribute the fluid most evenly throughout the system. With the engine spinning you can take a survey to get a rough idea of the temperature.
Now as for the fluid temperatures them selves there are a few factors at play. The gearbox will typically draw a lot of its heat from the block of the engine. This will bring the fluid temperature up to near the sump temperature over time. The sump temperature is likely within 10-20* of the coolant temperature of everything is in working order. The sump temperature will rise with RPM and load over time as well. A healthy transmission will generate its own heat when driven in under-drive or overdrive over long periods as well. This is due to the loading on the bearings and the load on the gearwheels (especially helical cut like is typical on road cars) when not driven in direct drive (typically 4th gear). This again will increase with load and speed as well.
The transfer case on these trucks generates quite a bit of heat due to the nature of the design. There is no direct rear output. This means that as you are going down the road the load is always going through the gear set on its way to the drive axle. This heat generated will also increase with speed and load. Heat is also passed through from the transmission to the transfer case.
I am not very familiar with the under body layout of these trucks as mine was never as originally equipped during my ownership. The environmental conditions also have a large influence on these temperatures. Typically the under body is exposed to the air that has passed though and heated by the radiator. The only way that these gear boxes and transfer cases are cooled is through convection (ignoring the heat transmitted from the gearbox back tot he engine). The hotter the air around them the hotter they will run. The exhaust routing can transmit a lot heat into the undercarriage of the vehicle as well.
On my particular setup with an aluminum housed 5 speed overdrive gearbox and intermediate reduction box, and a cast iron Orion transfer case my steady state fluid temperatures on a 100* day are typically as follows:
It takes over an hour to reach steady state typically. My Orion will not dissipate heat nearly as effectively as the original cast aluminum case will.
My sump temperature is typically 10*f above the engine coolant temperature. The transmission usually will follow the oil temperature unless seeing high load (steep grade) in overdrive or under drive for extended periods. It takes a long time for the gearbox to get up to sump temperature (at least 45 mins). If the transmission temp starts to get elevated I drop into 4th gear and the temperature will quickly drop down to the sump temp or lower over a few mins. the intermediate box only heats up through the conduction of heat from the gearbox and transfer case. It stays the coolest but over the period of hours it will average out between the transfer case and transmission temperature.
The transfer case however makes quite a bit of heat. I had to remove my lower skid plate on this last trip through from SoCal to Colorado during the heat wave we have been having. The transfer case will typically get up to 100-120* above ambient. The temps will rise from there on large grades if I push the diesel engine. I have seen fluid temperatures as high as 250*f when really pushing it up the mountain (keep in mind it was 120*f outside when i went through Las Vegas on that trip) and the 80 mph speed limit through Utah didn't help. I pull over when the temperatures get much over 245* and let it idle down with the Orion in neutral for about 10 mins when this happens. The temperature of the transfer case fluid will easily drop 20-30*f during that time buying me an hour or more over the road during these conditions.
As for the rear end, the full floater gets a ton of airflow over it so I haven't bothered to monitor it. Its especially exposed when your tuck is tall like mine.
If you would like I can try to get a survey of my setup with an infrared gun to help compare the fluid and skin temperatures next time I'm on a trip like this.
I hope that helps/makes sense!
Thanks,
Mike
