Tranny Rebuild -Shadetree Mechanic Style
There is another sst kit on eBay right now. Looks complete.
Edit: I was wrong there are two sets on eBay. Don't see that every day.
Haven't checked my FSM but is this the same SST kit suggested for the A343F?
Jim- great thread, I had to read the whole thing straight through to the end. I picked up an A343F for free (no reverse) from a fellow mud member last weekend and plan on doing this same thing (however not with real time updates on here as you did, not as confident in a successful outcome :p). Strictly as a learning excorise though, since my 97 only has 110k miles on it. I wonder how different the A343F will look from the A440F from the inside.
-Patrick
do you have a picture of the tool that compress the clutches assembly to remove the snap ring?
Let me try and find it in the garage but honestly it was a PVC endcap that I cut out and drilled a hole at the top to run a peice of all thread through so I could compress the springs.
I'm working on a foot pedal device to compress the springs that is much easier that all thread.
Duration, Cost and Tools
Okay, I'm feeling pretty confident about the rebuild so here are the details.
[Timing]
Well all total the rig was down for about three months. With working 50 hours per week and waiting on parts as I found them to be bad, this was the result.
Consolidated; the timing was about 50-65 hours. Keep in mind that this was the first time to rebuild a tranny, this involved: dropping the tranny, disassembly, cleaning, inspection, measurements, and assembly.
After the first rebuild the learning curve going way down resulting in a shorter leadtime. Let's hope it does not happen again.
[Cost/Tools]
Vendor Part/Tool Cost Notes
Toyota-- Bolt, Flange Type-- $30.03-- oil pump to tranny housing
Toyota-- Bolt, Washer Base-- $12.78-- front/rear oil pump plates
Toyota-- Spacer-- $7.65-- To hold pin in Manual Valve Lever. Old part can't be reused.
Toyota-- Race, Thrust Bearing-- $17.57-- Bought due to crack condition.
Axiom-- Tranny Rebuild Kit-- $316.68-- All gaskets, steel plates, clutches and seals.
Kit is also available without steels for about $184.00
AutoZone-- Transmission Filter-- $21.88
AutoZone-- Loctite 248 Threadlocker--$11.98 Loctite® QuickStix™ 248™ Threadlocker, Medium Strength
AutoZone-- Case of ATF-- $34.68-- 12 quarts of ATF
Lowes-- Metric Lock Washer-- $0.68-- For Rear Bearing Seal Housing
Lowes-- Metric Hex Socket Head-- $4.00-- For Rear Bearing Seal Housing
Ace Hardware-- Bolts and washers-- $6.87-- Assorted for rear tranny cover, accumulator cover
Sub-Total Parts Cost $464.80
Tools needed to buy:
Harbor Freight Tools-- 5" C-Clamp-- $9.98-- For compressing the spring rings on Clutch Assy.
Harbor Freight Tools-- Pliers-- $4.99-- For 'C' clips
Harbor Freight Tools-- 3.5 Gallon Parts Washer-- $49.99 -- To clean all parts.
Menards-- 1/2" square tube x 1/16"T-- $7.50-- To make SST Check Ball Spring Compressor 09350-06100
Menards-- Parts cleaning Brush-- $9.99-- For parts cleaning Tank
Sears-- Punch 1/2x MDS-- $5.99-- Needed to stake Spacer 90560-20008
SPX-- Replacer, Rear Bearing-- $31.14 --
Wholesale Tool-- 1/4x1/2x18" Flat Steel-- $10.80-- Used to make SST Plate Bar 09350-06090
Sub-total Tools Cost $130.38
Total Cost $595.18
Tool Needed:
Air Compressor with air nozzles. Used for air drying parts and getting pistons out.
Hammer
Screwdrivers
1/8" punch. Used to drive the push pin out on the
Snap Ring Pliers
Neuton Meter / inch pd torque wrench
Needle nose Pliers
Feeler Gauges
Magnetic Fingers
Inside Bore Micrometer Preferably mm
Calipers Preferably mm
paper and pencil
Dental picks or sometime of that nature
Petroleum Jelly
Dial Indicator
Coat Hangers Used to make SST's 09350-06110, 09350-06120
8,10,12,14 mm deep well/short sockets
crescent wrench
Pan big enough to soak clutches in
At least four to five bins to keep major subcomponents together.
And you'll need ATF in a Febreze spray bottle.
I have more details in an Excel spreadsheet if you want it. Just email me and I'll send it to you. I also have more pics that's not on MUD if you'd like.
I hope this helps someone out if the need arises.
[Resourses]
Order Manuals:
To order a Factory Repair Manual from Toyota call 1 (800) 622 2033
Publication number for the A440F ( MY 1991-1992) RM258U
Publication number for the A442F ( MY 1993-1995) RM388
Publication number for the A343F ( MY 1995andup) RM479
The manual runs about $15.00 plus shipping.
Also please note that the Special Service Tools are only listed in the Tranny repair manuals. And the Factory Service Manuals for that matter.
Order Special Service Tools:
SPX Corporation, OTC
28635 Mound Road
Warren, MI 48092-3499
Phone 1-800-933-8335
Business Hours:
8:00 am - 6:00 pm EST
Fax 1-800-578-7375
or
1-586-578-7375
Order Tranny rebuild kit:
Axiom Automotive Technologies
Edit 11.26.2011:
Axiom has been acquired by Transtar Industries:
Transmission Parts - Transtar Industries Inc.
Or your local Toyota Dealer
Enjoy.
One of the best reviews and detailed work on a tranny, congrats Jimmy and thanks so much for sharing!
