tranny just plain sucks.
Seattle
The "project" drove for the first time ever last week. Everything is pretty solid, except the brakes (see touchy brakes thread) and the tranny. It drove all right but the tranny stinks. I was told it is out of a '71 and is a three speed non-sync first gear? Which explains why it sucks so bad to drive. So, I'd like a four speed or a automatic. I am reading that a sm420 bolts up to a three speeds transfer? Is there an automatic that is short enough to still keep enough length in the rear drive line? Any suggestions?
awp_cruiser said:
Tranny just plain sucks .
I thought trannys were supposed to suck ... :rolleyes:
TY
I've never heard of the conversion, but isnt there a 2 speed chevy(?powerglide?) trannie? That might be short enough. The 3 speed toyota trannie has a bit of a trick to get it into first with out grinding. When you come to a stop, with the clutch depressed, slip it into third then quickly back into first. It stops the grining.
Dave
I put a 4 speed australian tanny in my landcruiser with a 3 speed T case and it works sweet gives you a lower 1st gear too so it really crawls in low range all you need to adapt it, is a kit for JT that has a new bearing drive gear and seal to go into you 3 speed then you don't have to mess with your drive shafts. fairly simple install to!
A turbo 350 or a 4 speed?
I see that MAF has Aussie 4 speeds for $650 used. I am going to hit a up a couple of jyards and see what kind of a SM deal I can find. Classic Cruisers has a nice conversion for a 3sp TC to SM for $375. I like the idea of the transfer case rotating down too. Little less clearance, but with SOA that might help more in the long run. So I am leaning towards a SM conversion, and I have read lots of good things from people who have made the switch.
If I do go Turbo, I feel like I'll have to go Orion ($$$) as well to get the lower ratio that I'd like. For a daily driver the auto would be almost too nice....
This guy is running a three-speed Toyota transmission. If he changes to a Toyota, or any other four-speed tranny, he will need to modify his driveshafts...
If it where me, I'd cruise the boards and pick up a h42 and transfer for maybe $500. Granted the gearing isn't as nice as a h41 or sm420/465, but for normal driving, you'll have a tough time finding anything that's as easy to install or that will shift as nice.
OK, did I hear correct: in the same space needed for the th350 adapter (5+") to t-case you can run a Toybox and get the lower gear options and adapter for the same length? If so, such a deal!
It is just a matter of getting used to it and you can get used to anything. I went from a H42 4sp, which was really nice driving in town to a sm420, which is basically a synchro 3 speed for most driving. Now that I am used to it, I get annoyed driving my son's 5sp truck because I have to shift so often.
