Lots of work, today... including finding a too-good-to-be-true mounting location for the relay block.
Pictured: The mounted relay block.
In case you're having trouble seeing it...
Pictured: C'mon...the machine screw in place of the trim cap was a dead giveaway...
Somehow, the gods decided that an unused trim clip hole and the trim screw hole above it and to the left were the literal perfect size and location for opposite corners of the relay block's mounting feet to bolt into...and the process of bolting it in was far less awkward than this sentence.
It's so,
so tempting to use this location: it's already there, it's the right size, it allows mechanical fasteners, and the trim panel snaps right over it with no protests...but it's just kind of in the wrong place. It makes the wiring longer (and I'm not sure how long the trailer harness I've ordered actually is) and the two corner mounts aren't as strong as having all four corners bolted in, and I'm concerned about bending the lower interior sheetmetal edge if I have to remove a stuck relay. So, that being the case, I think I'm going to mount the relay block back here.
Not Pictured: Jack and tool kit.
See that area to the left of the vent? That's where we're going...and I think I'm going to go with an adhesive solution, here. I have some .250" 5052 plate, so I can cut a rectangle from that and then drill and tap some holes that the relay block can bolt to...and the plate itself can go directly to the flat portion of the exterior sheetmetal by way of a VHB tape layer. I have some stuff that should easily handle the temperature of the metal on a hot summer day - that seems to be about 135°F, for reference, as measured today with the sun directly on the panel in question for five or six hours - so it shouldn't be too difficult to get the relay block in place tomorrow. At least, that's the plan.
Oh, speaking of the relay block...
Pictured: This was fun*.
* - Fun. A word which here means "incredibly confusing and stressful for someone who doesn't really understand the electricity-flavored things."
I feel that a capable person could have gotten this entire relay block sorted and wired in about an hour...but I am not that person. It took me...well,
several hours...and I even had a giant diagram that I made that helped me keep everything completely straightforward and clear, despite my relays having a minor difference in their arrangement from the relays in the diagram from the Page 1 link.
Pictured: Admittedly, drawing the white wire baffled me for a bit.
Fun Fact: that whiteboard is the most useful thing in the garage. $70 on
Amazon, I think...and that's about the best $70 I've ever spent. Of course, it's now probably $270, but I digress: it really helped me keep everything in order... because there's no doubt that I would have screwed things up without it. And by the end of the night...
Pictured: Feelin' Hella good.
That... actually, that isn't half-bad. It's
tight underneath - like, wire-squishing tight - but it's all together, and every circuit is intact after my having poked, prodded, pushed, shoved and threatened all of the wiring loops into a semblance of compactness. Don't ask to see that picture: witchcraft may or may not have been involved, and as we all know, that kind of thing doesn't show up on film. Bottom line is this: the relays are all wired, and all of the pins are showing the proper connectivity...so unless I've bodged it entirely...
It...
Could...
Work!
< insert Gene Wilder face here >
