Track Bar Q...
jaymar
SoCal
What is meant by stabilize suspension? Thx!
Wheels on the ground, setteled to ride height.
So you unbolt both sides before you raise the vehicle to pull the wheels for the next step?
Anytime arms with bushings are being worked on, the hardware should be left loose, then torqued when the vehicle is back on the ground, at ride height.
No press at the moment so none, but I want to check torque after shop replaces bushings. Also want to make sure they do it right,,,
After you get the 80 from the shop, loosen all suspension hardware while it sits on its own wheels. Move the body around a little bit from the front and sides before starting the torquing process. Then using the FSM, torque ONLY the specific nuts or bolts. The suspension hardware are serrated to maintain their torque and putting the socket on the incorrect hardware will ruin these serrations.
