^You won't have a problem at all with those kinds of weights. The AHC system is not delicate and actually very capable and robust. Australians regularly modify AHC for even higher weight capacities, and run them through the outback hard.
One thing to understand is, like any normal sprung vehicle, if you load it up, it will sag. The AHC system works likewise outside of a certain threshold which is perfectly normal. Meaning, it's got a constant height capability within a certain weight limit (i.e. 1000lbs, I don't know exactly but it's at least that). When that's exceeded, it goes to a non-constant height mode like a traditional spring system. That is AHC will continue to support the 1000lbs, but the mechanical spring will take up the addition weight beyond that like a normal car by compression and lowering in ride height. The readout on the dash is two things, a height selector and height readout. It may say 'L' because it's telling you that the suspension is now being compressed - which is perfectly normal and not indicative of the system failing in any way!
Even more, the AHC system has dynamic dampening that no other system has. With all that added weight, it can adjust for more dampening. Which means the ride with all that extra weight is still buttery and has control to match.
If only all those people that chucked AHC understands what they're missing...
In general, I'd say it's good to throw in spacers as that will bring back some of the constant height capability due to the suspensions mechanical springs age (imagine those non AHC trucks that have the same age issue dragging their rear ends now). 30mm spacer rear. And 3.5x turns to each front torsion bar to bring it completely back into spec. So instead of 1000lbs of constant height capability, it will have 1300lbs of constant height performance (again, ballpark) If you want more, there are upgrade springs and/or airbags for more.
~5600lbs and 850lbs tongue. Tows beautifully. I have it in 'L' in this picture for my kids to get out, but it never dropped to L when I didn't want it to.
