Towing conundrum
Tow vehicle is a 1990 HDJ81 with 1hd-t, auto, trans cooler, trans temp gauge, stock water temp gauge on dash, boost gauge and pyro. 2.5" exhaust ported out the side with no bends or restrictions.
Trailer is a 28' Airstream GVWR 7600#
Normal driving at 100kph, boost 9-10, pyro 550-650, trans 160-180, water mid way up gauge.
Towing AS at 100kph, boost 11, pyro 800-900, trans 180-190, water mid way.
All the above in OD.
At 90-100kph with some hills (big hills) I pop out of OD, boost 11, pyro 1250 (I back off at this point), trans 190, water temp starts to climb to 3/4 level.
Water temp did climb more and faster but I removed my offroad lights which pretty well blocked the rad either side of tranny cooler.
So my point? Should I be concerned about these numbers? Biggest concern being water temp. The truck does OK, 168hp and 268 ftlbs but she's pulling maybe 90-95% capacity I feel.
I'm worried that it may be too much and now I'm starting to think about a 3/4 diesel PU.
BTW, I tow in OD because I watch the gauges and the truck can handle it, plus it's the difference between 2200rpm and 3000rpm.
Also trans temp probe is in the pan, pyro pre turbo.
Are you towing only on flat land or are there mountains. I personal;ly wouldn't feel comfortable towing that much weight up a mtn pass, but across a few hundred miles of flat lands, it could be ok.
If your stock gauge is anything like the petrol engines, then you are about 220ish at 3/4 as it doesn't start increasing until you allready are too hot. I would install an after market temp gauge so you can better monitor the situation and do something early like turn off the AC or turn on the heat or back off the gas a bit if the temp starts climbing.
First off thats a freakin huge trailer - too big for a cruiser with a 5000lb towing limit. From what I have read thats a high exhaust temp. Its a little weird that with a 25% increase in rpm you get only an additional 11lbs boost, unless of course thats where the wastegate opens. You could crank up the fuel a little and go for a bigger exhaust to cool it down.
Karl
Towing Limit
Boy do you guys ever get screwed or what??
The towing limit for the JDM HDJ81 from Toyota is 3500kg which converts loosely to 7716.17 pounds.
I have a factory Toyota Towbar labelled with the rating in kg.
I wonder why that is because structurally your truck should be identical to ours, right? And the 1FZ-FE actually rates at more power, being as its 212hp, 270lb ft of torque....
But I still wish I had a diesel :( damn you and your fuel efficiency!!
I tow a lot every day, but not that much. You are really pushing it.
I pull as much as a ton most of the time, but I do not exceed that.
You are asking too much from an 80.
In my youth I saw a stock 40 pull a fully loaded school bus up the Matatzal mountains. The bus was dead in the water. It had no power. The mountain pass was 26 miles at over 6,000 feet.
I have no doubt that my 80 will pull anything that I put behind it, but it will never be a sports car. I do not expect it to go fast.
If I need a race car, I will drive an Altima or Celica. My LC is a workhorse, and I will treat it as such. It is a Clydesdale in a world of racehorses.
My LC is a hard working truck in a world of wimpy soft rigs.
mostly pretty flat around here.
the 81 is rated at 7700# though.
I'd thought about the adding a temp gauge but once I add that then it would be a pressure gauge and where do I stop?
Is this a water cooled turbo jacket? If so, your turbos are heat soaking the water, causing a rise in temps. If not, the turbos are heat soaking the oil. You have a rise in trans temps, rise in turbo, expect a rise in water/oil. You can add an additional trans cooler (cheapest) and/or engine oil cooler. IME, the oil cooler gives a lot more benefit for long term temp rises, water is good for spikes, but a lot of capacity is needed compared to an oil cooler.
I tow over 5000lbs regularly with only airbags and weight distribution hitch, it's axle loading and tire ratings that make a bigger difference (along with multiple axle trailer brakes). I really think someone in the US got overly paranoid about the trailer specs, same truck everywhere else uses the bumper hitch and have higher ratings for the 80.
SJ
94 FZJ80 Supercharged
