Towing an LX450
Bonsall, CA
As in almost any vehicle (especially the ones which are always in constant modification), sometimes you experience problems on the road. The manual is not so happy about towing the car with all (any) wheels on the ground. Probably this is due to the auto transmission.
But is it absolutely true? What can go wrong if I switch to 'N' and put the transfer case to 'N'. To the best of my limited knowledge, no motion from the wheels would be transferred to the tranny and engine. So in my opinion I can tow the car as far as I want. Am I right?
Sounds good, I know several have exprssed concern that during all that movement the tcase may go back into gear, not sure how. Even though you are in nuetral you are still spinning the bearings in your Tcase.
I would pull both drive shafts and then there would not be any issues.
First of all, you'd need to put the transmission in P so that nothing is rotating in there. However, I think the issue maybe that the Tcase is not getting lubricated since the rear DS is still spinning.
All Jeep Tcase are the NPxxx series which have their Tcase oil pumps driven by the rear DS. Consequently, they can be flat towed. Not sure about the 80s though!
A search will reveal many threads on this issue!
there is much more to it than just the transmission, if you tow with the frotn wheels on a dolly or sling and the rear wheels on the road you will destroy the Viscous coupler in the transfer case, even it the transfer is in neutral.
you can flat tow all 4 wheels on the road or all 4 wheels can be on a trailer or flat bed (none on road or rotating)
NEVER tow one axle rotating and one not, if you must tow this way remove the drive shaft to the axle on the road.
RT,
I'm trying to think..., if you dolly the front axle and remove the rear driveshaft, what damage could occur? Seems like the rear diff would be the only thing spinning, but without the driveshaft engaged could that cause any damage?
:beer:
Rookie2
RT,
:beer:
Rookie2
if you had the front on a strap or dolly and the rear on the road with the drive shaft installed the VC would cook,
with the drive shaft removed no problem, tow as far as you like no harm
You guys are talking right past each other. He said "what damage would occur if the rear shaft is removed (as you recommended)"? Answer: None, which is the whole point RT recommended removing it.
DougM
I guess so, but I wasn't sure by this statement:
that RT was inferring this is more of a last resort, and even with the driveshaft off, there may be some risk of bunging something up. In hindsight, maybe I read to much into that part.
:beer:
Rookie2
naw you are not reading too much, it was poorly phrased, I should have stated it with more detail as two separate thoughts,
I guess I do think of it as kind of a last resort, pulling a shaft on the side of the road is not fun, especially of the bolts fight you (they often do) and when done towing you gotta put them back in.
best practice is to have it towed on a roll back truck, all tires off the road, should my precious 80 ever need a tow that is what I would demand.
And I thought the only difference between P and N was the pawl in park?
huh...
what about a NON VC?
Dropping the DS is out of the Q right now...:bang: having the bolts cut off isn't :bang:
bump....:Ben Stein: anyone?...anyone?
If it was a standard diff, the carrier (to pinion) would be rotating. I've got it in tranns neutral and TC neutral. What is the AWD TC's equivalent to a carrier? And can it withstand about an hour and a half of free rotation? Does it have lubrication? Is it in a oil bath, or does it require a pump?
I've taken it around the block, but 75 miles at 70mph is another story...
huh...
This thread had been about the FZJ80, what vehicle are you asking about?
fj...no vc...92
being pulled via fZj80 :D
Ok that is progress, the diferentials are the same between the FZJ anf FJ as far as towing is concerned,
The FZJ transfer is where the VC lives, the HF2AV transfer also has an oil pump that move gear oil to various parts when the input from the transmission is turning,
Not sure how diffrent the transfer cse in the FJ80 is, weather it has lube when being towed engine off or not,
any 91/92 guys got a copy of thier OM handy? what does it say?
If u wana tow it, front wheels on a dolly and remove the rear drive shaft. no worries!
Hilux can't do that because he can't remove the rear DS.....
According to what RT posted, the oil pump is driven by the idle speed gear....what drives that?
any time the input from the transmission to the transfer case is driven the middle shaft of the transfer and the pump attached to it spins, in neutral being towed it does not. see page 62 of the PDF
only the output shaft of the transfer case would be turning when being towed in neutral
