tourque spliter?
LOS ANGELES
Website
www.destechservices.com
I saw it on an old man-a-fre catalog. It said that it will mate your 4speed to your v8 no problem and give your tranny a 27% overdrive. If im not blowing smoke, would that apply to a 5speed as well? I mean would it give it a 6th speed?:confused: Sorry guys but I'm trying to figure it out.
Howdy! I am running one of these. It's called a Ranger 3 overdrive/underdrive. I got mine thru AA about 14 years ago. Bolts up to a Chevy 350 on the front and an H42/H41, and maybe the H55f 5 speed. It is fully syncronized, and I can split any/every gear whenever I want, including reverse. Works in H2, H4, L2, and L4 ranges. With just my original transmission and transfer, I now have 16 gears forward, and 4 in reverse. Some of those gear ratios do overlap, but who cares. It's about 8" long, so you can move a 350 forward more and keep the driveline in the original position. John
nice!!! sooo... I can git a 5 plus v8 juice and make a 6 speed shake? I bet you can.
Howdy! I think you have to use the H55f from a 6 cylinder diesel, as the one from a 4 cylinder is a bit different on the input shaft. The good news is that when I drive in down the freeway ramps, I start off in the lower range on the splitter and go thru all four gears, then after I blend into traffic, I put in up into the higher range on the splitter, just like a 5 speed. The bad news is that there are some trade offs. Some folks don't like the additional noise that the splitter makes when running in overdrive/underdrive as opposed to straight. It's not real loud, but you can definitely hear it. Also,and more important, it does make a noticeable difference in the way it shifts. The weight of the extra gears in the splitter drags on the input shaft of the transmission enough that it makes the syncros in the trans work harder to adjust the speed of the rotating mass to allow real smooth shifting. I totally rebuilt my 4 speed, thinking it was getting old and tired because it shifted kind of heavy. Didn't make any difference. I just drive my rig like a BIG truck, and take my time shifting. It ain't exactly no speed demon anyway. I usually double clutch it when it is cold out, until the driveline get all warmed up. Whenever I have a newby in the right seat, I usually split shift it like an 8 speed just to freak them out. Too much of that will give me tennis elbow. John
Howdy! The 4 speed and 5 speed are direct interchange, only if your current 4 speed has the extra empty case attached to it, between it and the transfer case. I don't know what the cutoff date is for that. Earlier 4 speeds like the FJ40's and early FJ60's are shorter than the 5 speed by several inches. The Ranger is about 8 inches long, so the transmission and transfer case would have to move back that much to make room for it if you are staying with the 2F, regardless of which transmission you use. I would think that a Ranger plus an H55f would be a bit of OverKill, as that would give you two overdrives. On paper, you could do 75+ at 1200 rpm, but that's not very effective in the real world. The 5 speed would be a great drop-in for a stock setup, but the Ranger is more for a custom engine/driveline swap. While I do like my Ranger, I wish I had used an NV 4500 with a granny gear and an overdrive. John
Clutch - pop out of gear - release clutch - clutch - put into new gear - release clutch
LAST ?. What is double clutching? :confused:
Howdy! Ok, good question. Standard 4 speed transmission (non-overdrive) has basically two sections: input and output. In high gear (4th), both sections are going the same speed. In all other gears, including reverse, the input is going much faster than the output. Syncros are a little magic device that helps the input section speed up or slow down to match the speed of the output section as you push the clutch in and move the shift lever. When the syncros are old and tired, or cold and full of heavy grease, like 90-140w, they loose some, or all, of their ability to perform as designed. This results in stiff and crunchy gear changes, which make the driver appear to be quite the rookie!! By pushing in the clutch and shifting into neutral, then letting the clutch back out, you can increase or decrease the engine speed which helps the input section match the speed of the output section for smoother shifting. After this brief engagement while in neutral, then again push the clutch down and continue to shift into the desired gear. TA-DA!! You just double-clutched. When you get really good at matching engine speed to ground speed, then you can actually just go ahead and shift without using the clutch. But that is another lesson for a later date. John
now i know why, when criusing down hill with clutch pressed, when I release the clutch in neutral the tranny starts whinning like if its in gear or something..... And yes! My tranny is noisy. Heck, I thought my bearings where going out. So I will mess with that. Is that why I have to slide it in first before sliding in reverse when reverse dont what to engage? I do that and it saves alot of clunking grind noise.:D
thanks man, I learned something.
Howdy! Sometimes the drag of the pilot bearing will cause the input section to rotate along with the engine speed, when you are in neutral, or have the clutch pushed in. Putting it into first gear will stop the rotation, and then it is much easier to shift into reverse, since it has no syncros. John
Like inkpot, I have a Ranger in my FJ40. Originally it was the adapter to allow the SBC (small block Chevy) to mate up to the 4 speed. This was great because you didn't need to muck with the driveline and positioned the motor more favourably. Like inpot says, it's a bit noisy. Eventually I replaced the 4 speed with an SM420, now I drive this truck like a big rig, lots of double clutching. Good thing is, I don't hear the Ranger as much... either the SM420 or three speed transfer case drowns it out. The noise level is unbelievable when cruising down the highway, lot's of straight cut gears. I replaced the back of the Ranger to mate up to the 420. The gearing is great, you never need to use brakes even on a long grade. The gear ratio on the 420 leaves a bit to be desired, especially 2nd -> 3rd. On the trail the bonus is pretty much the same, doesn't matter what gear the guy in front of you is using you can pretty much always find a matching ratio.
i drove an FJ45 a few weekends ago with a 350 and a torque splitter.
really a cool thing to have in your rig, the extra overdrive is quite nice on the highway. as mentioned, it is quite noisy, just straight cut gears whining when in the over drive gear.
double clutch or touching the skiny to keep rpm up to the next shift it's as usual as walk in my case .. I never thought about that until I drive my wife manual FZJ80 .. maybe it came with me from my days drivings MOGs .. ( diesel MOGs .. )
