Torque Numbers..
Calgary, Alberta - Canada
Been working on my front-end bearing this past weekend. All went fine with the valuable help of the FAQ and members advices. I am now ready to button 'er up and I have peered through numerous posts regarding the preload when I came across a couple of points.
- I am using the LandTank preload method, which seems to be favourable by many Mudders and stood the test of time/trail.
To recap it:
  1. Torque adjusting nut to 45 ft-lbs
  2. Turn the hub left and right a few times
  3. Loosen the nut until can be turned by hand and repeat 1 & 2
  4. Torque the adjusting nut to 10 ft-lbs
  5. Install lock washer and lock nut
  6. Torque the outer lock nut to 45 ft-lbs
  7. Check the turning force with the fish scale between 8-12 lbs
The torque value on the lock nut (outer) is what is confusing me, the FSM says torque to 65 ft-lbs and the Landtank procedure suggests 45 ft-lbs, same as the inner nut. Which value to use, 45 or 65?
- The FSM says to torque the 6 flange nuts (on the cone washers) to 26 ft-lbs, I read somewhere that the FSM is mistaken and they actually meant 26 in-lbs (about 2 ft-lbs) instead, is that correct? It sounds reasonable considering the size of the studs those nuts are mounted on, just double checking..
Thanks for the help all along..
Cheers,
I stripped a couple of the studs on my rear hub by over-tightening the cone washer nuts with a torque wrench. My recommendation now is just to use a regular length (8" or so) ratchet and snug the nuts. No need for leverage or extra force.
0tsiP
It's more about the amout of rolling resistance that you have than the torque of the adjuster and retaining nut.
I just tighten the inner nut, turn the hub several times to ensure the bearings are set, then loosen the nut and retighten untill resistance is between 8-12 lbs. I lean towards 12 with new bearings, and I usually do it by feel. Then install the locking retainer and tighten the outer nut to 60 ft/lbs. Check resistance again and you're done!!
Don't forget to check wheel play again after 100 miles or so.
Hope this helps.
I'm doing this next week hopefully and have never heard about the FSM being wrong...That is a huge difference in values...Any know for sure?
As for the preload...I was shown by a Toyota master tech his technique. Torque the inner nut to the FSM value, sping the hub several times, loosen nut, and repeat (2-3 times, whatever you feel like). Then loosen and torque to the inner nut to what you can get with a 3/4" drive holding it with one hand right where the drive and the hub socket some together using just your wrist for torque. He is right on everytime :steer:
One thing I've always been confused on is that you set the preload before locking down the lock washer and then torqueing the outer nut. Then you are supposed to check the preload again right but after you crank down the outer nut the preload seems to go way up :confused:
I don't think the flange nuts (w/cone washers) is 2 ft-lbs, I would follow the FSM. The nuts that hold the felt/rubber seals is a real low number though.
Last time I did the wheel bearing/birf job, I torqued the adjusting nut to 45 ft-lbs, turned the hub back and forth several times, loosened the nut and then re-tightened until I was in the upper end of the preload range ~10lbs w/ fish scale (I used the same torque wrench still set at 45 ft-lbs, and came close but did not reach it), then turned the hub a few times and confirmed preload. Then I tightened the locknut to 45ft-lbs.
The first time I did it, I followed the FSM and felt that I had too loose of wheel bearings when all was said and done, that's why I did it differently this last time.
Jeff that's because there's backlash in the threads- when you tighten the outer nut the inner one is shifting to engage with the other side of the threads, away from you. Put the fish scale back in the tackle box- set the preload, back it all off, then tighten the inner nut until it's snug, but you can still move the thrust washer with a screwdriver. Put the lock washer on and torque the outer nut to 47... you should no longer be able to move the thrust washer with the screwdriver. If you can still move the thrust washer with the screwdriver once all is cranked down the bearing is a little too loose, you're going for "just barely can't move it" which I know is an impossibility but go with it.
this has been the money spot for me, and there's a real simple test when all is said and done. too loose after 50 miles or so and you can make the bearing move by shaking the tire. too tight and the hub gets hot, just compare it to the back hubs, and the other side. Neither symptom marks the end of the world if caught within a couple hundred miles, IMO, and can be remedied in about an hour in any parking lot.
And I stripped my studs taking them to 26 recently, I'm going to stop at 20-22 from now on.
Thanks Tim :D
