Torn and ashamed
Vidor, TX
I shamefully have a 94 fj80 180,000mile w/ out lockers, all stock except for a bent TJM bumper. I got it at a good price 40,000 miles ago. I've only taken of the road twice. That was enough to get me excited and wanting more. Now, after researching, I need lockers. Question of the day: should I sell mine and find one with factory lockers or should I invest in the old one with aftermarket lockers?
I'd stay stick to what you have and get after market lockers! The cruiser seems to have been good to you so now it's time for you to be good to it and start making it look and perform better! ;p
First off, you don't "need" lockers to take your 80 off road. There's lots of places you can go in an unlocked 80 which are unaccessible to lesser vehicles.
Once you find you're regularly trying to get places your truck doesn't have thew traction to reach, then look into lockers.
Lastly, it's always better to go with the devil you know. You've known your truck for 40K miles - what's that, two years?
You know its recent service history, and any idiosyncrasies it may have. Better to retrofit lockers into your friend than start from mile zero with something with unknown issues.
You already have the cruiser, if its not a piece of crap, keep it and toss in some aftermarket. When I got mine it was a cream puff inside and out without lockers.
Lets just say she's not so pretty anymore (don't tell her I said that though), but runs like a champ and has lockers now. :)
40,000 in less than 1 year
I've had this truck for a little less than one year, and the only thing I've had to do to it was change the front pinion seal. I just don't know if it's worth (finacially speaking) keeping and rebuilding or investing in a lower mileage truck w/ lockers.
Does anyone know about how much it cost to do an engine rebuild on these things? If I do it all myself (minus the machining)? and turnkey at a shop?
I agree, you don't NEED lockers to go wheeling. In fact, in some ways you become a better driver when can't rely on lockers. Keep it and drive it like you stole it!
Cheers.
Keep what you have. When you do the lockers, you will have to rebuild the front end anyway. If you buy another cruiser, you will need to rebuild the front so you are sure of the last time (and how well) it was done. Basically, any other cruiser you trade out will need the same TLC that your truck needs now.
Jasper motors sells an engine for the 80's. I haven't heard much about them for how well the 80's work but alot of their engines are put in FJ40s. If nothing else, you can check their prices so you have something to compare it to.
I'll add this, keep it and when you add the lockers, regear depending on which tire size you have. I'm of the opinion that the 4:10's are long leeged for stock tires, much less anything oversized. Search for Nay's regear postings for more info.
What all does a front end rebuild include? Cost? Difficulty?
Cost: $300ish from Cdan (rough estimate)
Difficulty: If you have a basic metric tool set, and a few specialized tools (seal puller, 54m socket, snap ring pliers, brass drift, the DVD) it's not that hard. Time-wise, most people say 2 full days, I took 3 lazy ones :D
Check the FAQ for a good write up about the job, and grab a Factory Service Manual (FSM)
weak engine
it has 180,000 miles. so it's about that time i would assume. plus, it's weak. twice i've used it to launch a small aluminum flat bottom boat, when i went to pull up out of the ramp, with just a small empty boat trailer, it couldn't do it. i had to put in low to pull off of the ramp. that to me is a sign that a rebuild is in the near future. i would prefer a swap with a new or low mileage one, but i imagine the price is significantly more. any advice is welcomed.
:lol:
You really need to look around this site more.
That's what Lo is for. Go find a lower mileage 80 to drive; I doubt you'll notice any difference in power, as I doubt you would with a re-build (unless it's a swap).
Just start buildin' it up already! :)
i don't think it's just that weak of an engin, i'm talking about a 200-300lb trailer on a the slight incline. we use my friends truck (91 cruiser w/ the smaller engine) and he almost idles up the ramp. my just bogs down. i'll look around for the cost of a engine rebuild.
Could be your tranny kickdown cable needing adjustment. You could seriously be trying to go up the incline in second or third gear and not know it.
Get everything tuned up and adjusted, and then see where you are.
Also, the best advice you can get is that you don't need lockers. Not yet. I wheeled for a decade without lockers and never had a problem. They are only necessary for the big stuff.
how about a good tune up first. You actually may just have something wrong.
I doubt a rebuild is in order. Highly doubt. 180k miles isn't that much. Have look around here. many are well above that.
Mine has 185k and isn't weak at all. You might just need a good tune up, plugs etc.
it drives fine, my wife drives it every day and it has no problems on the road. i mean it will cruise at 80mph with no problem. maybe my trailer weighs more than i think. i've done a tune up. new plugs wires, distributor, belts, hoses, fuel system cleaning. the only tune i haven't done is the timing belt. my next step will be to check my compression. that's the only way i know to be sure. has anyone done the rebuild on this engine? expensive?
