I have been prepairing for the install of my OME Med kit. I have read all the great info on various posts. I am going to buy a Tie rod/ball joint lifter for the SS. I have purchased new bolts for the lower rear shock mounts. I am also going to buy a cheap impact wrench from sears. I have a couple of impact sockets already but no deep sockets.
I would love to put together a recommended tool list for an OME install. Please chime in on tools that you used and for what purpose. Specifically for my edification what deep sockets.
Here is my list as it sits:
1/2" breaker bar & extending pipe
1/2" socket wrench
1/2" impact wrench (Optional)
Pickle fork or tie rod end/ball joint lifter for steering stabilizer
Pry bar
6 ton jack stands
Floor jack
bottle jack
12mmx1.25 tap (clean up rear shock mounts)
Torch
PB blaster
Regular sockets: 12mm, 17mm, 22mm, 24mm
Deep sockets: 17mm, ??
Screw driver (for clamps on extended diff breathers)
Large pipe wrench for shock body
Vice grips
Racheting box end wrench 17mm for ds shock bolt
BFH & Drift for control arm bolts
Rachet strap to hold front axel
Latex gloves (beware allergic reactions)
Beer & pizza for assistants
Good installation instructions can be found at the following sites:
http://www.sleeoffroad.com/technical/tz_ome.htm
Landtanks Castor Correction Template:
https://forum.ih8mud.com/showthread.php?t=134590
I will add more as my brain kicks in gear.
1/2" socket wrench
Pry bar
6 ton jack stands
Floor jack
bottle jack
Torch
PB blaster
Vice grips
