Toe adjustment
You did loosen the clamps?
Heat and candle wax...let the wax wick like solder on a fitting.
You can remove one tie rod at a time from the knuckle and put a large box end over the stud and turn it to break the threads loose and work and reinstall
You can also hit the threaded portion of the tie rod with a hammer pretty hard. It will not hurt it, but it can knock all the corrosion loose. I have had to do this on a lot of 80 tie rods and drag links. John
Maybe I wasn't using enough force with the pipe wrench as I was thinking I would snap a tie rod in the process, I will try all the above mentioned. Thanks
I had to clamp mine in my big vise and use my largest pipe wrench with a cheater pipe to get them off. Luckily I was replacing them, but they were rusted very well onto there. I used penetrating oil and heat and finally got them off with a lot of effort.
My truck was originally from Houston and has very little rust in most places.
I hope yours go smoother. Measure the overall length before you take it apart. That way you can get the toe fairly close when you put it back together. Good Luck!
