To correct or not to correct...
Modesto, CA
Installed the Slee 2.5 inch OME medium kit a few weeks ago; all but the CC bushings. I've driven the truck quite a bit since then, including a trip to Sequoia National Park, and the truck drives just fine. No pulling or unusual behavior I can detect.
It was my intention right from the start to install the CC bushings, but now I'm questioning it. Maybe someone can help me decide. I just took the truck down to a local 4x4 shop and was basically talked out of doing the caster correction, in spite of the fact that the guy stood to make a quick $200 on the job. I think he was giving me his honest opinion, but I don't know if he was right or not. He said that:
1. Adjusting the caster is completely unnecessary if the truck is not pulling or behaving badly.
2. Adjusting the caster will affect the camber, possibly in a bad way.
3. The polyurethane bushings are going to "squeak like hell".
Here is my before and after numbers:
Before:
LF RF
Camber 0.6 Camber 0.4
Caster 3.1 Caster 3.1
Toe 0.02 Toe 0.02
All were in spec.
After:
LF RF
Camber 0.1 Camter 0.2
Caster -0.2 Caster -0.3
Toe 0.6 Toe 0.13
Caster and Camber are out of spec; camber only slightly...
If I decide to do the job, I'll just save the money and pull the lower control arms myself and take them to someone else locally who has an automotive press. The question remains: should I fix it if it's not broken?
Thanks,
I would do it. Why woudn't you want it to drive better? Sure it's ok...
It doesn't become REALLY darty until you get further negative. I don't know where he's getting the "really squeaky" part as I've never heard anyone complaining about that with caster bushings.
you'll notice more dartiness in evasive maneuvers. IMO...do it.
Rick, are you saying that the OME bushings are insufficient to correct my caster based on the numbers I provided? I know Slee's are supposed to be good for another degree over what the OME's provide. I have your template for the OME bushings, and that is what I was going to use to do the job. So...should I ditch them and go with the Slee bushings?
Caster spec is 2-4 degrees. 3 degrees is the sweet spot. Slee's will get you there. OME will get you to the minimum.
Sure you think it drives fine now. Wait til you correct it.
Do it. I drove my truck post-lift pre-caster correction for a couple of months. It was darty and not 'relaxing'. I found myself with both hands on the wheel all of the time.
I have the OME 2.5" heavies front & back, so I had a bit more height than you're going to have with mediums.
Still, I think you'll find that the drivability and return to center on steering and overall driving zen will improve with the caster correction. The OME bushings that came with your kit will likely do just fine. I have never had one squeek.
The people at OME who designed that kit knew what they were doing. If you go back to the same mechanic, make SURE he understands how they go in and what they do. If he doesn't want to take the time to understand it, find another mechanic. Also, make sure he understands about the bolts on the control arms and how they turn weird.
you'll be just short of the spec. Do you think you might want to go higher at some point? It will definitely drive better than it does now with the OME bushings in there.
If you plan on adding weight and not adding spacers or going to a heavy spring then they will be fine.
Before:
LF RF
Toe 0.02 Toe 0.02
All were in spec.
After:
LF RF
Toe 0.6 Toe 0.13
Thanks,
Stop that squeeking!
Just installed poly bushings. Was told to use plenty of grease on the outside. No grease when pressing them in though!
