J = light duty
Don't think J=light duty, think it is supposed to =jeep.
All 70 series cruisers, and other series, have J in the model, both light and heavy duty.
Yes correct. Thanks for the correction.
If LJ71, its the L which designates light duty.
hmmm isn't the light duty swb prado petrol 70 series called RJ70 or vice versa
As already mentioned, the L in LJ70 is the engine designation, L=2L or 2L-T, the R in RJ70 (a petrol/gasser light duty Prado) =22R.If LJ71, its the L which designates light duty.
Yes 22r petrol is RJ70
2.4L deisel is LJ70
These 70's are known as light duty, as they have the 8" axles with coil springs as opposed to the 9".
LJ78/kzj71/kzj78 light duty.
"1984 - 70 Series was introduced. 70Heavy as a soft-top, hard-top, FRP top, utility, cab-chassis, and Troop Carrier (inward facing rear seats).The petrol engine was replaced with a 4.0-litre 3F engine. The 70 Light had a four-wheel coil spring solid-axle suspension for better ride quality. This lighter duty version of the Land Cruiser had the 22R 2.4-litre gasoline engine, 2L and 2L-T ( turbo ) 2.4-litre diesel engines commonly found in the Toyota Hilux. The 70 Light was sold in some markets as the Bundera or the Landcruiser II, later called 70 Prado. "
From Wiki
Same as the other models, the letters preceding the J in the cruiser model codes are the engine designations, KZJ=1KZ-T/1KZ-TE engine, HZJ=1HZ, HDJ=1HD-T/1HD-FT/1HD-FTE, etc., etc.
The -T is for turbo, the -TE is turbo with electronic injection.
Not sure about the F in -FT and -FTE, maybe it designates four valves per cylinder?
The LJ70 and RJ70 are called the Bundera rather than Prado or Land Cruiser II here in Australia, and we don't get the LWB/4-door LJ78/79.
The 70/71/72/73/74/75/76/77/78/78 part of the model code refers to the 70 series and the sort of designates chassis/body/suspension type.
In your first post your answered it yourself, then it was answered again in the second post.So what is the conclusion???
What should it be called
LJ78/LJ71 or ?????
My question is still unanswered.
It is a KZJ71.
I have this TLC prado Model Year 93 Recond Year 2000
Engine 1KZTE
Chasis KZJ71
We call it here Toyota Prado 3 Door
Can anyone elaborate what exactly it is i.e., Series Model etc
anything with "L" is light duty, yes it is the designation of the engine but that engine ended up in light duty vehicles
hence my statement:
stay away from vehicles with LJ/LN in the vin (same with the KZ but that is for another thread)
