Tire size
Canada
I have settled on a tire, but am wondering about tire size:
BF Goodrich ATs
295 x 75 x 16
or
305 x 70 x 16
or
315 x 75 x 16 - Do I need to re-gear or do any other mods to make this work?
Any thoughts, pros and cons are appreciated. '94 80 with 3" front & 2" rear OME. Currently running 285 x 75 x 16...looks a little lost with the lift, and older tread.
thanks
315's will rub under full flex on a OME lift that is not the OME J with L shock combo. 305's are the same height as your 285's, so they'll look lost, too.
Go 295's and get the Nitto Terra Grapplers instead of the BFG's and you'll increase overall performance while saving some coin. The 315's will fill the wheel well better...but that's a slippery slope.
You don't have to regear with any of these sizes, but you'll want to.
School me on tire size. How is a 285 the same height as a 305? I'm new to the 16" rim and am trying to make the same decision.
285 is mm width, 75 sidewall height as a percentage of the width (75% of 285 is 213.75mm sidewall height), 16 is wheel diameter.
A 305/70/16 is 305mm wide and has 213.5mm sidewall height (70% of 305 is 213.5)
This means that even though the 305/70/16 is wider, the tire height is equal to the 285/75/16.
Yes...also a potential of 6 mos of snow, and they don't realy plow much. The rig would see 5% of it's time off road.
Get trxus MT's for those conditions. Head and shoulders above BFG AT - with the BFG you trade extra tread life for a rubber compound that will freeze in serious winter conditions and lose a great deal of it's already middle ground winter capability.
In any case, you sound like a good candidate for a modern siped MT.
Posted by chimyz
With the lift that you have, I would say go for 295 75 16. Check out the link FirstToy posted. The tires are quiet on pavement and should look good with your OME lift.
