Tire pressure
Montana
This must be a tired subject (waka waka) but working on tire pressure on the 40. Only had it about a month and a half (as good a rig as I imagined) came on aftermarket 16’s (I do have the original 15’s) w a nice set of Yokohama 7.50 x 16. Not new but still a season left and nicer than I’ll be able to replace them with, so milking em a bit. Been messing around with tire pressure, pretty much always following the owners manual. Something like: “sand/dirt/rock= 22f 26r, regular driving = 24f 28r, highway (65mph+)=26f 30r. All seaming pretty good, ride wise, but sound and look a little low. No I have not chalk tested. Also, all the tire pressure threads I look at here on mud are opposite, meaning more pressure up front and less in rear as opposed to owners manual recommendations for 40 hard top. I’m enjoying trying different things but there’s a lot of knowledge on this forum and would love to get some thoughts here. Thanks in advance,
Mitch
Use the pressure listed of the sidewall of the tire and go from there. Older tires definitely get louder as the get older. Check the age of the tire, I think after 8-9 (??) years they recommend changing them despite tread thickness.
I run 35 lbs in my 40 for everyday driving. 33 x 10.5 on 15" rims - All Terrains
I run 40 lbs in everything else. When wheeling I drop down to 16 lbs - Mud Terrains
Are they actually 750r16 ? As in they are radial?
If they are the bias yoka 750x16 they start somewhat loud and get louder... that’s bias ply... bias is loud and wear quickly
Which Yokohama do you have?
Most are a medium to heavier duty ply ... strong sidewalk and need to run a much lower pressure to flex them
Hey
hey Johnny, they’re the M-93k radial “hyparadial”. 7.50R16. Sweet tire really
For street pressure, get some kid's chalk and draw a thick line across the width of the tire. Keep rolling the vehicle over the chalk line for each pressure test to see if the chalk has been scrubbed away evenly across the tire. If the pressure is too high, only the center area will be scrubbed. If too low, only the edges get scrubbed. My Taco took about 28 lbs, and the 40 about the same.
Ok, this’ll need done for a good reference. Sounds like it’s; to the empty school parking lot this evening.
