Sure! Let's take it step by step:
For the LT285/70R17:
1. P285/50R20 @ 33psi = 2315 lbs Load Limit
2. Since you are going from a P-Metric tire to an LT-Metric tire, apply the 1.1 correction: 2315 / 1.1 = 2105 lbs Load Limit
3. Find LT285/70R17 (Single) in the Toyo Tables and follow over to find 2105 lbs: This is in the column for 35psi
4. Ergo, the RCTIP for the LT285/70R17 tire on your LX570 is 35psi F/R
And for the LT285/75R17:
3. Find LT285/75R17 (Single) in the Toyo Tables and follow over to find 2105 lbs: The first column (35psi) shows 2215 lbs which is more than what you need, but is the minimum safe inflation pressure for LT-Metric tires so you use this minimum
4. Ergo, the RCTIP for the LT285/75R17 tire on your LX570 is 35psi F/R
Clear as mud, right?
HTH
