Tips for installing rear 3rd member?
Cody, WY
Putting in my regeared 3rd members. Got the front Diff in no problem but the rear diff is giving me problems lining it up with the studs while bench-pressing it up there.
Any tips other than hit the gym?:hillbilly:
Was contemplating welding up a cradle for my jack tonight but dont have the metal for it right now.
I was able to balance it on a jack while a friend ran the jack.
If you can weld up a cradle it's probably worth doing.
Thanks for the input, I'll try that with the jack. Might just mock up a cradle with wood first and see if that makes a difference.
Can you shoot some pics so we can see what we are up against and how to best make a cradle?
I have to drop the Aussie in mine.
Have your wife show you how to do it. :rimshot:
It's a little heavier than the front, but once I got mine on my chest, it was no real problem.
Had a friend come over and give it a try heaving it up there without the jack, much easier with two people. Main issue also was I was trying to line up the studs rather than the ring gear and carrier.
I have pics on my phone of the diffs out I'll PM you them when I get a chance tomorrow.
lay down facing the front of the vehicle and put a thick book on your chest. take a few deep breathes and have a friend lay the 3rd on your chest........nudge yourself in place and perform the most controlled bench press you have ever done in your life, thus matching up all the studs with the holes.
once you are done don't let the third slide all the way down.......let it sit at the ends of the studs and have a friend or you can start putting fipg on the mating surface of the axle.
follow the instructions per label on back of the fipg tube.
really much easier if you have a creepy krawler and a friend that has foresight!
Did this first minus the phonebook. The ring gear just kept catching on me. Got it tonight doing basically the same thing.
always wear protection while being under! Glad everything worked out!
