Timing Question
My 11/69 F engine did a lot of the same. I chased down everything until landing on the fuel pump. The diaphragm had started to go but was not so bad that I noticed it under-preforming in the drive way. It kept up ad idle but couldnt under load. Eventually it got worse and worse and I replaced it with a unit from Racer65.
img_0425-jpg.1475295
The pumps were not exactly the same, but are definitely reverse compatible. Personally I wanted to replace the braided line with built in fittings with regular line and clamps anyway. The old stuff was shot
img_0429-jpg.1475296
It ran great after this. Good luck!
@S4Cruiser I have a timing light but I honestly can't see the timing mark. May be the old eyes or the timing mark may just be to rusty to see. Help will be appreciated.
Got it...I'll toss my light and a paint pen in my tool box.
On the front of fuel-related issues, if you have a toasted fuel pump, then I'd wonder if its deterioration would cause a tough time for the carb's needle valve as well?
At the end and there is end to this problem :), .....well there is no end but you know what I mean, after you make your list and start down the path of return, you have will start cleaning, check alignment issues and flat out replacing items just because it's old and for piece of mind it just makes it safe and fun to drive with no worries.
Good post. I have spent more than three years working on this truck and I want it to last at least until I assume room temp. And I have my grandchildren in there occasionally and I want them to be safe and have fun.
To the subject of this thread: no, the symptoms are not inline with timing too advanced or retarded.
But on the timing question, where is the vac hose for dissy originating on engine? A pic would be most helpful.
I was hoping it was the timing since that might be the easiest to correct. The vacuum advance is coming off the carb which is a Weber.
Jim, I was referring not whether the timing was set too advanced or too retarded but whether it was able to advance with increasing rpm. My '71 would idle fine and run at low speed fine but if I tried to speed up the problems would occur because the timing couldn't advance due to problems in the distributor. Maybe that's what you're concerned about in asking how the vac hose to the distributor is hooked up?
Pete, the problem on your truck was a misfire when the ignition was under heavy load, caused by spark shorting out inside the metal-dusted dissy cap.
The reason for asking about vac hose routing is because USA carbs from 69-74 don't have a ported vacuum fitting for the dissy. The OP has changed to a carb that should have a ported vac fitting.
@FJ40Jim The carb is a Weber, installed in early 2016. The dizzy is a non-USA model with electronic pick-up installed in late 2017. The vacuum hose from the carb to the dizzy was also new. Haven't checked out the amount of vacuum yet. I am getting an electric fuel pump today and will check the vacuum once it is running.
Thanks Jim! Shows you what I know, duh
Spent part of the afternoon installing a new electric fuel pump, filter and regulator. The 40 had three filters and the gas line was so stiff it broke when I pulled it out. I removed the old pump and put on a blocking plate. When I turned the switch I heard the pump work and then hit the ignition and it fired right up. After letting it warm up for a little while I took it for a 25 mile test ride and when I hit the places it stumbled before it didn't. So far I'm happy and look forward to a tougher drive tomorrow and Sat.
Sounds good.
What model of fuel pump did you install? Apparently, the Weber needs a maximum of 3psi, what did you use for a pressure regulator? Do you have the electric choke, and fuel pump on the ignition (fused) or coil circuit? Relay switch?
RedLine fuel pump (99009.131) and Redline filter.with a Mr. Gasket (9710) adjustable regulator which I have set at 3 lbs. Electric choke on the carb and the pump is on a switched circuit. No relay switch. Maybe I will rewire the pump to a relay but for now I will leave it as is. Hope this helps.
This is your timing BB or ball with engine running and illuminated by the timing light strobe flash from # 1 Cylinder
Glad you appear to have found and fixed your problem!
I’ll add this anyway... maybe it will help someone else, at some point.
I had two “related” problems:
1. Engine died under load: after much frustration, I found the fuel filter wasn’t fully sealed. The problem only presented when the secondary kicked in and the fuel pump sucked air through the filter leak. Note: no fuel leak, but air drawn from outside.
2. Severe loss of power above 6k’ of altitude: I found the vacuum advance module, on the dissy, had developed a vacuum leak. Actually, it was probably always there... just got worse. Replaced the dissy with a vac advance DUI, using a relay. Fixed.
I no longer need to kick in my afterburners.
A note of caution, David... with an electric fuel pump, you really should ensure the pump is disabled, in the event of a loss of oil pressure... like the truck rolls and the engine dies... otherwise, fuel keeps pumping...
You can easily protect yourself by installing:
1. a T between your oil filter and your oil pressure sender. I used https://www.amazon.com/Squirrelly-Pressure-Sending-Adapter-Female/dp/B00QXK0QSW?tag=ihco-20
2. Installing an oil pressure safety switch (OPSS). I used this one. It kills power to my fuel pumps, when oil pressure falls below ( or equal to IIRC) 2psi... but, allows the pump to run, when starter is engaged (without oil pressure). https://www.amazon.com/Carter-A68301-Engine-Pressure-Switch/dp/B000CSWR10?tag=ihco-20
Three wires:
1. I = ignition
2. S = starter
3. P = Pump
I carries power to OPSS
OPSS “P” forwards power to pump, IF oil pressure is > 2psi OR starter (OPSS “S”) is engaged.
Hey Danny! Thank you for that link to the oil pressure shut off switch. I have a 1981 Nissan SD-22 diesel motor (going to put into a 1973 Datsun pickup that my dad bought new) that has an almost identical IP and operating system to the Toyota B motor. The IP is operated by what looks like a wiper motor and gearbox. It has three positions that are transferred to the IP, start (overinject, like a choke on a gasser), run, and shut down. The original wiring (both Toyota and Nissan) had a low oil pressure shut down. I have the "wiper motor" but don't have the original low oil pressure shut down system that is in the wiring. I was planning to wire in a buzzer warning signal for low oil pressure, but this oil pressure switch you linked to just might do what the original system did.
Thank you!
Don
