Timing Question
Hey Danny! Thank you for that link to the oil pressure shut off switch. I have a 1981 Nissan SD-22 diesel motor (going to put into a 1973 Datsun pickup that my dad bought new) that has an almost identical IP and operating system to the Toyota B motor. The IP is operated by what looks like a wiper motor and gearbox. It has three positions that are transferred to the IP, start (overinject, like a choke on a gasser), run, and shut down. The original wiring (both Toyota and Nissan) had a low oil pressure shut down. I have the "wiper motor" but don't have the original low oil pressure shut down system that is in the wiring. I was planning to wire in a buzzer warning signal for low oil pressure, but this oil pressure switch you linked to just might do what the original system did.
Thank you!
Don
Glad to help Don!!
I did something like what you need ... but, I don’t recall why...
I used the OPSS “P” feed to trigger a relay and fed battery power from relay 87a... in other words, send battery power when there is NO power to the relay trigger.
Oh! Now I remember... not my greatest idea, but it worked.
I wanted an idiot light, to indicate loss of oil pressure. Now, I’ve got one!
Now, when oil pressure drops < 2psi, the idiot light comes on.
Buuuut... the fuel pump has already shut down... so, I imagine the idiot is already aware that the engine died... not my greatest idea.
Caveat... to Dave... the engine will continue to run, with ignition on, after the pump shuts down... until the fuel line and carb are dry.
