Timing Jumping - I give up?
Installed an early non-usa distributor into my '74 40. With everyone's assitance I was able to get it done and start it right up first try. Since then I have been trying to fine tune things (idle smooth with a good vacuum reading), get rid of a "Popping" coming through the exhaust around 1500RPM, and get rid of a bogg down in the low RPM as I increase RPM. Thought it was bad gas so I added some HEET, filled the tank back up, changed filters, and replaced wires. Worked great yesterday- Drove for 30-40 minutes with no problems. Tried it today and the "popping" was back and timing seemed off.
So - I decided to check the timing. It was off?
It seems that the timing is jumping. I put it on the BB, tightened the dizzy, and check things out. Ran up the RPM (Pop was there) then returned it to idle and the thing nears stalls. Re-check the timing and it is retarded. WTF? I also notice that the timing jumps around at idle - is this normal?
I have extra info in a post called - NON-USA distributor Intsall from the past couple of days.
How can the timing jump around like that. One minute it is fine, the next it is not?
Any help is appreciated- I am out of ideas and patience. If anyone is in the Hampton Roads area that could offer some assitance please feel free to contact me. The only other option is to take it to the shop and I really do not want to do that.
Thanks,
Scott
Shot in the dark
Are you absolutely sure that you are checking/adjusting the timing at exactly the same idle speed each time? A different RPM would cause a timing change.
What is the history of this distibutor?
How is the bushing in the distributor? If this has play in it, you will not get accurate timing..
Good luck!
-Steve
I wouldn't expect that popping in the exhaust manifold and bogging down would be a timing issue in the first place. Popping is normal operation for a desmogged engine on decelertion and bogging down sounds like a carb problem.
My ignition timing (64 FJ40) used to jump around at idle too.
I got a Pertronix ignitor. It eliminates the points, which solves two problems you likely are facing. Your bushing is probably worn like Poser said, causing excessive runout in the distributor shaft which causes your dwell to be erratic (like rogers suggested). And even though the distributor doesn't move, a little change in dwell can make a noticeable change on the flywheel.
Pertronix has preset dwell and the magnetic pickup is tolerant of the movement due to a worn bushing.
Ideally, I should replace that bushing some day, but it's not affecting anything except itself at this point, so...
Thanks for the help guys. Ijust got the Distributor from Mark so I am extremely confident that it is not the distributor and the carb was rebuilt by Jim C.
I disconnected the vacuum line from the carb and plugged it. Loosened the hold down clamp and adjusted the timing. Idle seemed OK so I tightened things back up and ran up the RPM's. Dropped the RPMS down and the idle was super low.
I will check things by making a mark on the dist and block. Just to see if it is moving. I guess it couldbe possible that I have to really lock that clamp super tight.
Any other pointers?
Is the gear firmly anchored to the shaft? Very rare but it's possible the pin or key holding the gear in place is shorn. (shorn? sheared busted broke) Long shot.
I had 2 rebuilt non-usa dizzys do that. All the symptoms were exactly the same as the original poster.
The problem is that from the factory there was a solid pin holding the gear in place. The rebuild factories use a sheer pin. I guess there's just too much stress on the gear or something, because it took a long time to figure out the solid pin issue.
Pull the dizzy and check it out. If it's busted, find a drill bit that works and tack weld it in there carefully.
