Timing for partime
Maryborough,qld
I had purchased a complete part time kit for my 80, with the understanding that I would save me on fuel. Problem is no it has not. My 4by is a 1fzfe, auto box. I had changed the plugs, leads complete fuel clean out system. But I still get the same economy.
Is there a different timing or plug gap??.
Cheers
Cheers
You really need to install a hi-clone along with the part time kit. Then your fuel tank will automatically top up as you drive.
Cheers
Fuel mileage improvement by going part time 🤣 🤣 🤣 🤣 🤣 :flush: and since you are new you get the welcoming salute :flipoff2:
Your "understanding" is incorrect. This was proven about 10 years ago. The only possible gain is less wear in the front end.
Personally, I don't like the way the truck handles in rear wheel drive.
And if you break a front shaft just disengage hubs and drive home.
Wouldn't it be nice if it was that easy. Most times, a busted birfield will jam up your steering. Unless you're a trailer queen, you're pulling it apart to get home.
If you grenade a birfield then yes change it. But if you just strip out the star or have a mild break in the cage it’s doable. I’ve driven home Twice on broken birfields. I know it can jam up your steering but it didn’t happen those two times. I just pulled driveshaft and drive flanges and off I went. That being said, I like all wheel drive and have no plans to go part time.
